Old 10/21/06, 6:53 PM
aweston aweston is offline
Default dryer and bathroom vents
If a bathroom vent were to pass through a laundry room can both the bathroom vent and the gas dryer vent exit through the same wall. If so what is the distance they must be seperated by.
Old 10/21/06, 7:48 PM
lkrausz lkrausz is offline
Please Note: lkrausz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: dryer and bathroom vents
I don't see why not providing the dryer is electric and it can't backflow into the bathroom it would be OK to run them parallel.
Old 10/22/06, 6:39 AM
the dryer is a gas dryer. the way the house is set up is that the bathroom is on the first floor in the center. their is not a window, and the laundry room has just been added. therefore the bathroom exhaust exhaust is run through a soffit and exits approximately 6 feet from the floor in the laundry room. the gas dryer vent has not been run yet as this is a new addition. the owner is a friend of mine and he asked if the two could be vented on the same wall. I know their is a minimum ground to vent height, but was unsure about vent to vent.
Old 10/22/06, 10:38 AM
You cannot vent gas into the room, along with the lint, (carbon monoxide and fire). vent it to the outside and if there isn't enough ground clearance place a buried PVC up to the vent and exhaust 3ft. away from the house like a drain.
Old 10/22/06, 12:12 PM
both will exit to the outside on the same wall
Natural Gas Dryer in Bathroom pbennett1 Plumbing Inspections 18 9/22/08 2:52 AM
Dryer vents through roofs jfunderburk Exterior Inspections 10 11/17/07 11:48 PM
Finding bathroom vent terminations (under the insulation) kshepard Interior Inspections 26 11/5/07 6:40 PM
Bad Dryer and Bath Fan Venting Jkrt00 Inspecting HVAC Systems 3 3/14/06 12:07 AM
