Old 11/25/07, 3:44 PM
Barry Adair's Avatar
Default Dryer sheets potential hazard
I just got this email from an appliance tech that has done service for my clients.
Not so sure about all of the info but our lint filter did hold water and required further cleaning to remove the "film"
An ounce of prevention couldn't hurt.
Dryer Info....FOR REAL
INFO ABOUT CLOTHES DRYERS: The heating unit went out on my dryer! The gentleman that fixes things around the house for us told us that he wanted to show us something and he went over to the dryer and pulled out the lint filter. It was clean. (I always clean the lint from the filter after every load clothes.) He told us that he wanted to show us something; he took the filter over to the sink, ran hot water over it. The lint filter is made of a mesh material - I'm sure you know what your dryer's lint filter looks like. WELL...the hot water just sat on top of the mesh! It didn't go through it at all! He told us that dryer sheets cause a film over that mesh that's what burns out the heating unit. You can't SEE the film , but it's there. It's what is in the dryer sheets to make your clothes soft and static free - that nice fragrance too, you know how they can feel waxy when you take them out of the box, well this stuff builds up on your clothes and on your lint screen. This is also what causes dryer units to catch fire & potentially burn your house down with it! He said the best way to keep your dryer working for a very long time (& to keep your electric bill lower) is to take that filter out & wash it with hot soapy water & an old toothbrush (or other brush) at least every six months. He said that makes the life of the dryer at least twice as long! How about that!?! Learn something new everyday! I certainly didn't know dryer sheets would do that. So , I thought I'd share!
Note: I went to my dryer & tested my screen by running water on it. The water ran through a little bit but mostly collected all the water in the mesh screen. I washed it with warm soapy water & a nylon brush & I had it done in 30 seconds. Then when I rinsed it the water ran right Thru the screen! There wasn't any puddling at all! That repairman knew what he was talking about!
PLEASE PASS THIS ON TO OTHER PEOPLE IN YOUR ADDRESS BOOK. NOT ONLY COULD IT SAVE SOMEONE'S HOME , BUT IT COULD SAVE SOMEONE'S LIFE
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/25/07, 3:58 PM
Roy D. Cooke, Sr's Avatar
Default Re: Dryer sheets potential hazard
Thanks Barry.
fortunatly for us.
My wife and and I exceptionally reactive to smells including mould, smoke perfume, etcetera,so we use odour free dryer sheets, I could find no build up in our lint trap water went right through .
Great tip ........ Cookie
Old 11/25/07, 4:15 PM
mthomas2 mthomas2 is offline
http://www.truthorfiction.com/rumors/d/dryer-sheets.htm
Here's the note from Frigidaire
http://www.frigidaire.com/support/FAQ-Dryer.asp
Old 11/25/07, 10:57 PM
gporter's Avatar
gporter gporter is offline
Great Info
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 11/26/07, 6:31 AM
HELP editing comment???
It has been proven that dryer sheets can cause a film to build up over the mesh on the lint filter that may not be visibly detectable. This can block the filter using more energy to dry a load of clothes, cause the dryer to overheat shortening the life expectancy or potentially cause a fire. Remove the lint filter, wash it in hot soapy water lightly scrubbing with an old toothbrush or other soft bristle brush rinse in clear water and thoroughly dry before reinstalling. Perform this task at least every six months. This is also a great time to inspect all of your dryer connections and clean the flue and vent damper.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/26/07, 10:47 AM
FWIW, I would write it as "Some manufacurers recommend..." rather than "It has been proven....".
Old 11/26/07, 10:59 AM
James H. Bushart's Avatar
Good info. Thanks, Barry.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 11/26/07, 11:02 AM
Michael Larson's Avatar
Here is some info from Truth or Fiction.
Old 11/26/07, 11:19 AM
More good info. Thanks, Mike.
James H. Bushart
314-803-2167
Old 7/6/11, 3:04 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Some manufacturers caution that dryer sheets can cause a film to build up over the mesh on the lint filter that may or may not be visible. This film can block the filter preventing the proper flow of air through the unit causing the dryer to overheat which could lead to a fire. In the very least, this film can shorten the life expectancy of the dryer. Client should read the manufacturers warning regarding the use of dryer sheets to determine if there is a real risk with this particular manufacturer. Washing the lint filter in hot soapy water has been found to be good at removing the film deposited by dryer sheets. Perform this cleaning at least every six months. This is also a great time to inspect all of your dryer connections and clean the flue and vent damper.
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Old 7/6/11, 4:43 PM
That has been around for years. In 2002, I distributed a flyer on the same subject.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 7/6/11, 6:49 PM
Eric W. Augustin's Avatar
Eric W. Augustin Eric W. Augustin is offline
One time I walked around for the better part of a day with a dryer sheet inside my shirt. They're diabolical!
Eric W. Augustin
A1 Certified Home Inspections
If you can't explain it simply, you don't understand it well enough.
Albert Einstein
Old 7/6/11, 7:00 PM
Ben L. Garrison Ben L. Garrison is offline
I put 3-4 in each time I run the dryer... Definitely going to do that the instant I get home.
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/7/11, 12:32 AM
Jeffrey R. Jonas's Avatar
Heck, this thread has been around for years!
Old 7/7/11, 8:16 AM
Everything old is new again...
Eric W. Augustin
Albert Einstein
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 8 9/9/07 8:02 PM
Dryer lint filter senomoto Miscellaneous Discussion for Inspectors 6 5/14/06 11:01 AM
Bad Dryer and Bath Fan Venting Jkrt00 Inspecting HVAC Systems 3 3/14/06 12:07 AM
