tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
My first time seeing this, but I'm guessing it is a common sight to some....how to write it up? Colorado is a very dry climate...the laundry room didnt' show any signs of moisture from this vent. But it is a fire hazard if the lint screen doesn't get cleaned and there is lint build up in this....errr...box yes?
Thanks... |
Hi Tony,
Yes, the dryer vent should terminate outside of the property, and should have no restrictions that would cause a build up of lint. I usually recomend a smooth wall rigid duct for upgrade. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yep.
Tony,
Yes call it out. Should vent outside, moisture problems, fire hazard and allergies. Lots of dust and lint in the air. Bill Bill Emelander Professional Edge Home Inspection Grand Rapids and all of West Michigan NACHI #03111914 www.proedgehi.com |
Look at the lint build up on the walls. What's the allergen content like for the rest of the house? My nose is itching just thinking about it. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
I have a narrative that prints automtically with each report, which your welcome to have, and which reads as follows:"Faulty dryer vents have been responsible for thousands of fires each year, hundreds of injuries, and even deaths. The safest vents are smooth-walled metal ones that only travel a short distance; all other types should be regarded as suspect and inspected bi-annually to ensure that they do not contain trapped lint that harbors moisture and retards drying time."
As I say, this prints automatically, and I have several other narratives with which to describe a particular vent or comments on its condition. |
Hi. Gerry, hope you are fine.
Exhausting the dryer duct outside the property would be quite a task if you have two acres. ha. ha. got you! Marcel Best regards. |
I mean, I live on 15 acres. |
"Recommend that the dry vent be terminated outside so that birds can have adequate nesting material in the spring."
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 8 | 9/9/07 8:02 PM |
| Dryer vent | kblair1 | Inspecting HVAC Systems | 21 | 12/6/06 3:13 PM |
