The seller of this house is debating the fact that the house was built in the 1980's and that his "electrician friend" told him that there were no electrical panel clearance requirements in the code back then.
I found in the NEC 110.26 that there were requirements for workspace clearances all the way back to 1965, the dimensions have changes, but the requirement has been there for decades. Look at the picture and please let me know your thoughts. The tub platform extends to the wall the the panel is on. I had to stand on it to remove the panel cover. ![]() Andrew Constantine InspectPro Home Inspections Serving NC and SC Charlotte NC Home Inspections |
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
As you already know the sparkys feelings about this matter don't matter here. The code does and even more so common sense rules over this situation. Panel or tub have to be moved! Problem is that unless they can turn it around in the wall cavity they'll have to run a new SEC for the new location.
Clearance !?
WTF? It's a bathroom isn't it?! Don't need no clearance in a bathroom... ...it can't be there in the first place. "working together to get-IR-done" Bracebridge, Ontario: Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Electrical panel rating question | lking | Electrical Inspections | 6 | 2/10/12 9:51 PM |
| Help proof the safety section on inspecting electrical panels: read here | kshepard | Electrical Inspections | 56 | 1/1/12 6:58 PM |
| Electrical Safety Foundation International Links | jtedesco1 | Electrical Inspections | 5 | 12/8/07 3:10 PM |
