Does anyone use or know much about the electronic radon testing systems? I currently use the activated charcoal canisters but was wondering if it would be a benefit to go with the electronic type testing, any help would be appreciated.
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
http://www.sunnuclear.com/radon/radon.asp
Try looking at Sun Nuclear, and also do a search in the ancilliary threa for more info. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
There are those out there that feel we as home inspectors have to go beyond the minimum standards. Yet for some reason many home inspectors buy the cheapest/basic radon machine allowed and perform the minimum standard regarding Radon testing.
Just something I've noticed. |
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
I plan on getting licensed this year because of the large increase of Radon tests I have subbed out the last couple of years. I have used a few different Subs in my area. The one that uses the Sun Nuclear 1028 has by far the best looking reports. I did research and have concluded this is the machine I will be using as well. http://www.sunnuclear.com/radon/1028/1028.asp
The 1028 cost around $800.00 each.
I own 2 sun 1027's. The state has no problem with them as long as you follow protocals.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Bobby do you also perform Mitigation?
They are called " Professional Continuous Radon Monitors" by Sun Nuclear Corp.
I use 3 1027 models. I rarely ever get interference issues, in which case it interrupts downloading of the results, so then you do it again but move the monitor farther away fro source- that's all. You should use one per type of foundation in the home, place in the most habitable rooms. Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
And you don't place it in the lowest habitable room in the structure?
A home with a basement will get one in the basement= lowest inhabitable room. That is the typical arrangement with most homes. If same home has a crawlspace and there is a habitable room above the crawlspace- you place a monitor in that room too. If there is also a habitable room that is built on a Slab on grade foundation. You put a monitor in that room too. If the home is all of one type of foundation it gets one monitor and you can place another if you like for diagnostic purposes. Know what i mean? Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
That's how I do it in Ohio. I couldn't imagine leaving 3 monitors in one house.
Yeah, In Illinois that's how it is conducted according to the regulations for measurement. EACH foundation type is a completely separate situation. lf you are an Illinois licensed radon measurement tech and you wish to set a measurement in Illinois, you should represent each type of foundation.
So if you find a level below 4 PcIL in the basement, and you do not test a room over a gravel crawl.. how do you know there is not an elevated level there? There very well could be higher level as there is less to impede the gas from rising up Same goes for a room on a slab. How does a reading in the basement of the home count against that slab on grade room? If there is an elevated level of radon in the earth there, maybe it will be found above the action level. You cant know for sure but isn't it wise to assume. I want to see whats going on for the home as a whole. I mean, you cant be too careful - the stuff causes lung cancer after all. Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
How much does calibration cost? How often,I think my state is every thirty days.
| Radon Testing Kansas City | dmoriconi | Ancillary Inspection Services & Additional Topics | 1 | 1/11/09 3:11 PM |
| Final review of Newman's radon references! | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 12 | 10/4/08 12:23 PM |
| Radon Class in Oakville and Ottawa | mkyriacou | Canadian Inspectors | 9 | 2/2/08 11:48 PM |
| Ottawa to stiffen radon guidelines. | gromicko | Canadian Inspectors | 1 | 8/16/06 5:28 AM |
