What exactly are these vents above the fireplace in this picture? It is a metal firebox and the ducts angle down toward box.
Scott,
Those vents simply conduct the heat (from the fireplace below) into the living area. |
Exactly, those vents allow heated air to flow into the room. Typically, you will see some intake venting lower.
Thanks Larry & David. I figured as much. This is the first of it's kind I have run across. Wanted to confirm what I figured was the purpose.
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Hearth size??? | jcampbell | Inspecting HVAC Systems | 32 | 6/1/08 1:56 PM |
| The Rumford Fireplace: Safety vs. Efficiency | mbryan | Interior Inspections | 2 | 4/28/08 4:38 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
