Can y*u guess what it is?
F*r s*me reas*n, the key representing the letter after "n" st*pped fucnti*ning last night. P*ssibly I hit s*me c*mbinati*n *f keys that resulted in disabling the keys. Can any*ne help? Joseph A. Ferry, Esquire Two Penn Center Plaza Suite 200 Philadelphia, PA 19102 215-854-6444 tel. 215-243-8202 fax |
R*y C**ke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
mcraig is a non-member guest and is in no way affiliated with InterNACHI or its members.
This a aptop and now the "o" is working but the "etter after k" is acting up. Is my computer trying to gasight me? If so, it is working.
Joe
Plug an external keyboard into the laptop (if you have one). It will tell you if the laptop keyboard is screwed up or the computer itself. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Try pressing control & shift at the same time.
I've had similar problems happen on my laptop several times. usually a restart corrected it. Took me a while to figure out what I was accidently doing to cause this problem. Pressing control then shift at the same time produced this problem. Pressing them again corrected it. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
ntoll is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sounds like someone has been eating crackers over the keyboard again. Try blowing it out with canned air. Or....submerge the whole thing in a bucket of water. The crumbs will soften and stop interfering with the keys.
Things also seem to malfunction for me also on my keyboard once in a while,
and its seemingly caused by my fumble fingered combinations, that produce the weirdness... Note: xyz= any fumbled combinations The INSERT key and xyx will do similar, as well as the WINDOWS key and xyx... I usually do a cold reboot of my laptop, and that seems to straighten it out til next time... Steven Waskewicz Rest Assured Inspection Services, LLC. 719-510-7703 mobile all the time 719-495-7166 Fax. s_waskewicz@msn.com HVAC Lic. #10722 EPA cert.544143239730 www.restassuredinspection.com NACHIiid=NACHI06032370 |
I can help you Joe. Please send your CC # and password to. LOL.
No seriously I can help you. PM me. |
Check out Control Panel > Keyboard.
www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
Joe,
I venture you got something stuck under the keys that is moving around. A blow job should solve your keyboard problem. Cans of compressed air are available for this purpose. Keyboards like it like that. And shame on all of you whose mind went immediately to the gutter. Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
Some models of the Dell laptops had cheap keyboard connections that tend to oxidize when the laptop gets hot. Their CPX laptop was well known for this problem.
My suggestion is unless the laptop is relatively new (1 to 2 years old), transfer the data to a new laptop. The new models are light years ahead of the older technology. |
And as mysteriously as it came, it went away. Check out these o's and ell's.
I guess I was just being gaslighted. Joseph A. Ferry, Esquire Two Penn Center Plaza Suite 200 Philadelphia, PA 19102 215-854-6444 tel. 215-243-8202 fax |
