| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Reminder: If you are not yet a member of www.OverSeeIt.com ... join! Membership is free for InterNACHI members.
Your seem to have hit many of the topic points.
Sadly I know of a few past cons that would pull the driveway sealing scam. "Beware of any contractor who shows up at your door unannounced or calls you on the phone. Con artists must move every so often to frustrate law enforcement, so they have no fixed address and rely on door-to-door or phone solicitation. For the same reason, their invoices may contain only a P.O. box rather than a street address, and their van may have a magnetic sign rather than a painted-on logo." While this can be true.... There are also very honest and probably great contractors just starting out that are unable to afford proper marketing or painted on logos, and therefore must rely on a door to door approach and magnetic signs. Untill 4 months ago I was still using magnetic signs, and one of your approaches to marketing Move-In-Certified Inspections is a door to door approach. You should check the contractors credentials. make sure that licenses are valid and ask for references. Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
Thanks. The economy is bring out the bad guys everywhere.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
You're right, I deleted that part
Researcher and Technical Writer, InterNACHI |
We all know and express our sorrow to the family. This happened here in KC this past week. The father and grandfather were inspectors I understand
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Inspector listings by county | rcarter | Miscellaneous Discussion for Inspectors | 8 | 8/22/09 10:40 AM |
| California Home Inspections | whandley | Miscellaneous Discussion for Inspectors | 17 | 6/4/08 12:28 AM |
