Suprise... Hot breaker found at the bottom of panel (I turned it off after the picture and
told the the owner of the house). It did not feel that warm on the front so I am glad the IR camera found it. It was a 15 amp breaker with correct wire size. Did the breaker trip off? No. So what provides better protection from being sued... the SoP or aggressive inspection methods and tools? Now you know why I use the IR camera on ALL inspections. No exceptions. ![]() ![]() Looks like a fine fireplace with dry walls? Wrong. Moisture found above the mantel with IR camera. Your blind without it. ![]() ![]() Watch Thermal Imaging Video John McKenna, CMI (TREC #4565)
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 11/2/07 at 1:52 PM.. |
John I also have had my training and I question what you are showing especially on the breaker. You are not giving any specifics such as emissivity settings, reflective, What angle you were standing to the wall with the glass pic. The breaker indicated 272 degrees but you stated it did not feel that hot. 272 degrees you could not touch and their would have been something melted. I can make the camera read that high on a breaker with the wrong emissivity setting. What did your infrared thermometer read on the breaker. What did your moisture meter detect on the wall in relation to what your camera was detecting. Don't take me wrong I believe in these cameras also but I also believe in backing the camera with another test device as they taught in class.
Just as an after thought the fireplace you are indicating moisture within could also have been effected by a circulating ceiling fan or an A/C register pointed toward the wall. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Is there a SOP for home inspections which set the standards for its use and limitations? If not the courts will most likely set one when a peeved client feels some home inspector with a IR camera was negligent in rendering an opinion or omitting a scan or other instance where they feel harmed or suffered a loss. Is there an SOP for use of IR by the industry? Cheers, |
I always check areas with a moisture meter. And like Charlie said cool air blowing on the surface always appears darker or wet. Corners almost always are cooler and not moist.
The front felt a little warm but the heat was coming off the bottom. The plastic had deformed a little and I turned if off before any real damage took place. Wall had tons of moisture showing with moisture meter. Emissivity settings, and reflective consideration did not matter on this find, since it was verfied with double and triple methods. When you say to use other methods to verify, you are preaching to the choir. All I can say is Amen! John McKenna, CMI (TREC #4565)
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 11/2/07 at 5:31 PM.. |
how much the SoP protected them. I don't want any of my clients to have their house burn down... so I will try and find all I can. Others can debate about the legal issues and I will avoid staying out of court by finding as much as I can. I'm sure there are other inspectors who are smarter than me, but this is my plan. John McKenna, CMI (TREC #4565)
It was good old water penetration. John McKenna, CMI (TREC #4565)
Why debate the obvious? Your not building my confidence guys.
The breaker was HOT and the wall was WET. Trust me, I was there. John McKenna, CMI (TREC #4565)
How did the moisture get behind the wall? Was it sweating?
Happens all the time. John McKenna, CMI (TREC #4565)
I never intended to worry about the mirror. John McKenna, CMI (TREC #4565)
Once you find the anomaly in the image then you verify it with a moisture meter. The E setting of no value in finding and then verifying a moisture area. After you try and set your E settings, I can be through the rest of the house finding more problem areas. John McKenna, CMI (TREC #4565)
Here are some papers on emissivity:
http://www.callpie.com/documents/sea...ramation06.pdf http://www.flirthermography.com/medi...holm_FINAL.pdf |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
