Does anyone know the amount of water (Gal.) and weight (filled) of a typical hot-tub?
Sorry, this is the best picture I have. This tub was made for four people if this helps. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com Last edited by mkyriacou; 6/12/08 at 8:45 AM.. |
Go here for specs on one type of 4 person hot tub... http://www.fourseasonsrecreation.com...ts/la-spas.asp
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Water weighs 8.34lbs per gallon
100 Gallons 834 lbs 500 Gallons 4170 lbs simple math after that, how many gallons = total weight in tub + weight of tub Hope this helps, Curt |
Thanks Curt and Jeff!
So would this be a concern? This is a deck converted to a sun-room with a hot-tub. IMO this is not safe and was built without a permit. Comments please!! 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com Last edited by mkyriacou; 6/12/08 at 8:45 AM.. |
Example tub is 4 feet wide 5 feet long and 18 inches deep. (4*5= 20) (20 *1.5=30) (30 *7.5 =225 Gallons) if you want this in Canadian Gallons use 6.25 instead of 7.5 Canadain Gallon weighs 10 lb (Water is heavier in Canada) . ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thanks Roy!!
Can you please have a look at the photos and give me an assessment,or your opinion please. I have never come across something like this and I would appreciate your input. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
69" X 83" X 33" 175cm x 211cm x 86cm Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Mario, I would be very concerned because you can't observe the ledger board attachments.
Could you see anything from inside? You need to disclaim this IMHO. Express your concern and the limitaions of your inspection as a minimum.. |
But I have many concerns . Good call you have huge amount of weight and for sure it is does not have proper support. I also am concerned with moisture getting in with lack of proper flashing. I would say less then professional installation and feel it could have been built with out a permit. Further evaluation by qualified Person . ...Cookie Added. I have a disclamer on my reports that I do not inspect hot tubs. Many reasons many are not cleaned properly and lots fo people get rashes and skin diseases from them. Google hot tubs and see lots of law suits on hot tubs. http://www.medic8.com/infectious-dis...t-tub-rash.htm Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 1/30/08 at 10:50 AM.. |
Thanks Guys!! I appreciate your help on this.
From what I can see, it looks pretty stout.
Assuming, is not sufficient to call this out (in my opinion). Do we have deficiencies to support the assumption? Is it pulling away from the structure? Is the floor out of level? Broken framing members? Because we can't see the ledger board, can we assume it was not properly connected? For all we know the porch joists may go 8 feet into the house. My concern would be adequate footing. Did we dig/probe? Another, is a lack of building permit. Somebody's going to have to pay for that permit some time. A permit should have been obtained and inspected while construction was in progress. Anything other than this it's just a wild @ss guess. |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 9:57 PM |
