Ok folks this will be my first hotel inspection so any advice is well received. It is a 40 room quality Inn.
Thanks Paul Hope Hopes HOme Inspection |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What's your location
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
You will not be able to get into all the rooms. Make sure your client knows this. The only way you could ever get into all the rooms is with multiple trips. Also make sure your client knows you are not inspecting furniture etc. Know your ADA requirements and defer to proper code people for them.
Keith Runquist, CMI |
I have found that a hotel inspection works really good with two inspectors. You can get in and out of a room faster.
...............especially with bugs around.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
I have inspected numerous Hotels, like James said have a couple guys is the way to go, their simple and the money is good. Make sure you have access to the rooms as soon as the occupants are gone....I had a house Walkie-Talkie and Door Card on the last one, when someone checked out we went to the room, I had three other inspectors with me. 60 Units took all day, next day for the report. Their basically ditto, caulk at Tubs, loose Toilets, clean the Return Air Filter in the Wall A/C...etc. Last Holiday Inn I inspected I believe I charged $.25.00 per foot. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
If you are not an ADA expert, I would disclaim it clearly.
If you do take on the ADA evaluation, be sure your E&O covers it. Most HI policies do not cover ADA because by definition it is a code inspection. Philippe Heller The San Diego Real Estate Inspection Co. http://www.sdinspections.com www.facebook.com/sdinspections |
| Group Rates for Hotel Reservations - January Mtg. Melbourne | mshishilla1 | Florida Inspectors | 12 | 12/28/10 7:12 PM |
| MOLD SURVEY for a HOTEL ASTM STD 2418 E | jacaron | General Inspection Discussion | 0 | 4/15/10 9:18 AM |
| Pictures tell a great story | mlarson | Miscellaneous Discussion for Inspectors | 59 | 9/16/09 5:31 PM |
| Hotel Inspection | srinner | Commercial Inspections | 9 | 3/2/09 3:10 PM |
| Hotel insurance mitigation | rgrizzle | Miscellaneous Discussion for Inspectors | 4 | 9/5/07 6:10 PM |
