Old 6/29/09, 4:26 PM
gharms gharms is offline
Default Inspecting attic areas
I live in sacramento california and it is going to be around 106 degrees this afternoon. i have an inspection and i am assuming the attic in the building will be around 130 degrees. does anyone know at what temperture its to dangerous to inspect the attic area. thanks
Find an InterNACHI certified Mississippi Home Inspector (and anywhere else in North America)
Old 6/29/09, 4:40 PM
Default Re: Inspecting attic areas
I routinely inspect attics in excess of 140 degrees from April to October each year without any issue (other than perspiration ). I would imagine that the guys in AZ and TX have similar conditions. You must determine what is safe for you depending upon your health.
Abraham Lincoln
Old 6/29/09, 5:12 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
And LOTS of water/Gatorade!
Old 6/29/09, 6:22 PM
God has installed plenty of warning systems within your body to let you know when something is wrong..........its up to you to pay attention to same and take appropriate action.
With that said....depends on how long I am going to be there........obviously if you enter in an attic and the heat is overwhelming then document the temperature and why it was not inspected.
regards
Jeff
Old 6/29/09, 7:19 PM
James F. McKee's Avatar
pretty sure above 212 You will boil...below that i inspect them....jmho....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 6/29/09, 7:58 PM
James H. Bushart's Avatar
It's a good idea to let someone know you are up there, should you pass out.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 6/29/09, 8:09 PM
Vince Santos's Avatar
Vince Santos Vince Santos is online now
Inspected one on Friday that was 160 deg. I always wear my cool vest and drink plenty of water. Don't stay up there longer than you need to and be sure someone is around the hatch just in case something goes wrong.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 6/29/09, 9:25 PM
David A. Andersen's Avatar
You may wind up dead before anyone knows your even missing.
You may in fact die on your way to the next job.
I'm sure all these brave soles don't spend much time up there...
You won't even know what hit you!
Unless you realize your being Stupid!
If you quit sweating at any time, get help.
BPI# 5015804
Old 6/29/09, 9:29 PM
Mike Komatina Mike Komatina is offline
I live in Florida and the attic get very hot, June thru September i try to schedule appointment early am. But sometime it doesn't happen i tell my Buyer or Agents, When i am going into the attic or Crawl space if i am not out in 15 Minutes call the fire department, And i clock it with real time when going into the attic or Crawl space. they think i am joking when i tell them that, But when you here on the News that a Cable person or Alarm person has Die in the Attic they think again like NACHI SAID SAFETY FIRST.
Old 6/29/09, 9:30 PM
Joe Funderburk, CMI's Avatar
Take a wet towel with you. I drape it over my head or wrap it around my neck. Helps a lot.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/2/09, 7:25 PM
Originally Posted by mboyett View Post
OK, it was 104° in Austin today and this was the reading in the attic...not the underside of the sheathing, just the middle part of the attic space.
Attachment 29783
Is this you southern guy's reward for escaping winter?
Larry Kage, CMI
231 929 3525
Old 7/2/09, 7:40 PM
Wayne B. Wilson's Avatar
I had one last week black roof 95 out 165 in the attic only a quickie ,
Old 7/2/09, 11:14 PM
Philip J. Cavalcante Philip J. Cavalcante is offline
Ok guys it will take at lest 30 to 45 min at a 160 for your core temp to rise to a temp thats harmful (if healthy) i cant remember the last time i spent that much time in a attic even in good weather.
Old 7/2/09, 11:43 PM
rmaday's Avatar
lol Much different when all the mechanicals are up there.
Old 7/2/09, 11:56 PM
Michael Larson's Avatar
Mechanical in the attic?
Why would you do that when you have a perfectly fine basement?
Never underestimate the difficulty of changing false beliefs by facts.[/I] - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Heavy frost in attic mashburn Interior Inspections 19 12/30/07 8:40 PM
Attic Temperatures Can Pose Serious Risks jtedesco1 Interior Inspections 4 4/2/06 10:17 AM
