I get a monthly newsletter from Kaplan and thought this info may be of use to those who do Phase...as this is one of the most overlooked and omitted applications I see on slabs around here.
More Tips Anchor Bolts by John Bouldin This month I want to review anchor bolt and strap requirements and their purpose. One of the major forces that can operate against wood-framed structures is shear. Shear is a lateral/horizontal force that creates a tendency for the building to either rack out of plumb, or for the framing to slide off the foundation. It may be caused by high winds, tidal surge or flooding, and seismic activity. In fact, much of the damage done by Katrina involved shear forces. Anchor bolts (or straps) are primarily intended to prevent the framing from sliding off the foundation. They offer no help in preventing racking, and are of limited value in preventing uplift. In residential housing, the IRC calls for the following minimums for anchor bolt placement:
During a normal visual inspection, many of these bolts may not be visible due to band joist insulation, storage or other obstructions, and we cannot report on what we cannot see. But there are some instances where we would be particularly on the lookout for them. In cases where sill plates have been repaired or replaced due to decay or insect damage there’s a good chance that the replacement plate may be notched around the bolt, rendering it ineffective. Another important area to look for anchor bolts is at the small shear walls of garages. Many times these walls are less than 24” wide, but each sill plate still must have at least two bolts. A more recent phenomenon in newer construction is to have a sill plate properly bolted to the foundation, but the wall resting on top of it has its own separate bottom plate, which is only nailed into the bolted pressure-treated plate, and is usually notched around the bolts. Depending on the amount and type of nails, this may create problems. If the pressure treated plate is a corrosive type of treated wood, only hot-dipped galvanized or stainless steel nails may be used for this purpose, and it might require the services of an engineer to determine whether the nail solution meets the minimum requirements to prevent lateral movement. Certainly if these nails are regular common nails, we would expect them to deteriorate within a few years, and not be able to prevent lateral motion. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Plan on shooting a NACHI.TV commercial next time we're in town? Here are 10 tips... | inxil | Miscellaneous Discussion for Inspectors | 1 | 12/5/07 12:11 PM |
