If a product such as a TREX railing post is installed differently than the manufacturers specifications is this considered a material defect?
If something is blatantly framed incorrectly what kind of a defect is it? What is the proper verbage for reporting items found that are not consistent with the manufacturers recommended installation procedures? Thank you. Paul |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What you said would work just fine. "items __________ are not consistent with the manufacturers recommended installation procedures." My personal belief is, make your reports factually accurate but simply enough for the customer and those others who will be reading it. I use "bullet" statements that keep it short, direct and not littered with highly technical jargon that most people will not understand.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
In the case of the Trec rail post, if it is installed different than Manufactures suggested installation, it would be inconsistent with their instructions, not a material defect. It would be a defect, if due to the deviation from Manufactures Installations, the rail post fails to perform as intended, like withholding #200 of exerted pressure. Something framed incorrectly is workmanship that don't adhere to the Construction standard for framing. Depending on what is framed wrong, it could be defective to meet structural loads intended, or just doesn't meet standard construction practices. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 Last edited by mcyr; 11/17/10 at 8:18 PM.. Reason: Incomplete |
Thank you!
I came across a trex related issue here where I live. The floor joists were not 12" oc...I don't know if that is the manufactures spec but Municipal building inspectors would make you tear it down because trex on 16 oc bends in hot weather and doesn't go back to its original shape.
Just a footnote |
Scott, Trec deck should be installed per manufactures specifications which is per this table for span chart.
Trex Decking and Railing Span Chart (on centers) Commercial Decks, 2 x 6 Boards 24" (70 cm) 24" (70 cm) 16" (40.6 cm)Boardwalks & Marinas Residential Decks, Light Duty Docks, Residential/Daycare Playground Decking Loading 100psf (4826 Pa) 100psf (4826 Pa) 200psf (9576 Pa) 1” Boards 16" (40.6 cm) 16" (40.6 cm) 12" (30.5 cm) 2 x 4 20" (50.8 cm) 20" (50.8 cm) 16" (40.6 cm) Can be seen here; http://www.trex.com/build/installation-guides/index.htm Joist Spanning for Decking Trex ® decking meets all applicable national model building codes. The joists must be spaced on centers according to the chart below. Be sure that all joists are level and plumb. Trex decking must span at least three joists. For load-bearing applications such as hot tubs, planters, etc., consult a local building engineer or inspector for span recommendations. Paint the top of through spaces between boards. Code Listings Trex complies with all major model International Code Council evaluation service.building codes and has been evaluated by the LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
