rbusch is a non-member guest and is in no way affiliated with InterNACHI or its members.
I see this very often-- Attached garage with no insulation in attic above garage. I can not find any code on this subject. In the attached photos the area furthest away with insulation is above kitchen. The area without is garage. This just does not make sense to me, how cold will that kitchen be in January? I always recommended adding insulation in situations like this. But I can not believe this is to code.
024.jpg 025.jpg |
| Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America) |
What's the problem? The garage is not conditioned, neither is the attic. The insulation over the kitchen is to help keep conditioned air in the kitchen, and unconditioned air out of the kitchen. It doesn't matter for the garage.
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Typical new construction. Unless the buyer pays extra for an insulated garage, it isn't insulated. Code states that "insulation shall be installed around all habitable areas." Therefore the garage doesn't require insulation. The kitchen should have insulation, which it does and the rear wall of the garage should also be insulated.
What's worse is when a bathroom is installed on top of a garage, then the bathroom tile floor gets cold in the winter. It's a common complaint from owners. |
Be careful when inspecting areas adjacent to the garage, such as a laundry room. They often get no insulation either. Common defect.
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
The unconditioned garage air may get into the attic, but where does it go from there? Insulation over conditioned spaces should keep it out. |
I understand what you are saying. But its nice to see insulation over garage when it is adjacent to a living space. I guess this is a good example of Code is Minimum.
I don't see where adding insulation over the garage would have any affect on the temperature in the kitchen. The insulation is to separate conditioned spaces from unconditioned spaces. The garage and attic are both unconditioned, there is no reason to insulate between them unless you intend to condition the garage space itself.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Most people in this area use that area over the garage to store the blow up Santy Claus and other items that can withstand the high summers temps. Having insulation over an unheated / cooled garage is like putting a gold ring in a hog's snout. Might look good but complete waste of time and money and accomplishes nothing.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
What is it that the insulation over an unconditioned space will accomplish? |
Good point Joe. I often find that too, either a laundry room or breakfast area.
rspermo is a non-member guest and is in no way affiliated with InterNACHI or its members.
The garage is outside of the house's thermal boundry. As long as the home's walls that it shares with the garage are insulated that is fine. As long as the ceiling above the living area is insulated that is fine. If you have a knee wall in the attic that should be insulated with an air barrier. There is no need and no benefit from insulating an unconditioned space.
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree that insulating above the garage would have been a good idea and not all that costly when the place was built. Around here it's one of those ultimate luxuries to have an insulated garage with a bit of heat to get the snow off the cars. But not a requirement that I know of. |
Depending on your area, insulating a garage which is not conditioned is unwise.
It does nothing more than trap heat in the summer and cold during the winter. Also, why are you looking at code anyway?............ part of the problem HI's have are trying to be BI (building inspectors) which they are not. regards Jeff |
AMEN!
Good point Jeff, rule of thumb in Florida,,, no duct required, no insulation required. Only living area under air requires insulation.
| Poly being applied to Basement walls | dvalley | Interior Inspections | 40 | 11/24/09 11:49 PM |
| Garage door inspection procedure | bgromicko | General Inspection Discussion | 5 | 8/7/09 1:47 PM |
| Garage ceiling insulation | shand | General Inspection Discussion | 8 | 4/14/09 2:56 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 6:25 PM |
