Found something interesting by the bathtub the other day.
This picture is when the oven was at 350 degrees. Things really started getting warm when I put the oven on broil. (this unit was an electric oven in a 70's home that had been remodeled).
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 9/15/07 at 10:13 AM.. |
Hi John,
Did you recommend something to the buyer/seller with regard to the heat transfer? Or are you just showing what a great instrument the cams are?........... Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I don't find a 10 deg elevation in temperature to be remarkable.
The back of my oven is opposite the stair wall to by lower level and the stair side of the wall gets warm. |
I told him I was not sure if it was a big problem or not. Like I said, it started getting pretty warm once we put the oven on broil. John McKenna, CMI (TREC #4565)
Mike Chris, Santa Clara, Utah
NACHI: #05051385 HouseNspect@gmail.com www.housenspect.com activerain "A man's home is his castle . . . until the queen arrives." |
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
I just wanted to see If there was a difference in temperatures of the wood were termites were known to be and where they were not located. I scanned three window panes from the interior of the home two of them with known termites one without and I registered 2 degrees temp difference between the windows with and without. Not much difference in temps and don't think I would have recognized that as a problem if I had not had previous knowledge not that I go around looking for termites not my job I just thought it would be intersting. I have a good working relationship with this one termite company we look out for each other. I tell him the location in crawl spaces where I see his problems and he tells me where he sees some of my problems such as leaks 4 eyes are better than two. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good pick up though
Mic |
| Interesting Question? | jmckenna1 | Miscellaneous Discussion for Inspectors | 9 | 11/25/07 1:13 PM |
