Just had an interesting question posed? What is your thoughts?
Could be built on top of a spring.
Is it natural water or could it be town water ?
..... Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
At this point, I have given them the following answer...
(I really feel sorry for these folks and the problem they are having, because the estimated cost of repairs will be in the tens of thousands of dollars and they have not even begun to deal with stopping the moisture source or the mold issue yet.) My response: Quote:
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 11/25/07 at 12:56 AM.. |
People here run into springs all the time digging basements. Im not sure what would be correct but the older builders route it somewhere downhill with a drain system and seal it up. Could you pump it out? Also could you put dye in the water to see where it is going? Maybe pump it out and cut the water at the street for a while and see if it refills? What a mess!
and they said there was no problem with the plumbing. Who knows what it is? At this point, it seems that they liked my answer, for what it was worth. I wish I knew more so I could help them. John McKenna, CMI (TREC #4565)
If the area of TX that you are referring to has had as much annual rain fall as we have had up here this year you could very well be dealing with a spring that that the water level raise and lower with the water table. I have very similar problems in one of the towns I inspect in. One commercial building in particular was constructed over the top of a known free flowing spring. The engineers re-routed the water during the construction period and poured concrete troughs to allow the water to flow completely through the building. The building was constructed on the side of a hill so pumps were not installed just free flowing water. I about freaked out when observing this during the inspection as I had no previous knowledge of this spring.
My thinking would be springs/sink hole type situation in other words a big mess good luck Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
If there has been building around them water source (springs) have been moved towards their home like some have said here. I think it is a septic tank problem from the drain fields maybe. Just a shot in the dark
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
Have the water tested and see if it is chlorinated
All valid points... thanks.
After the water filters through the soil, then it may be hard to find any chlorine. The problem did not start for the first 80 + years .... wow. what a suprise. John McKenna, CMI (TREC #4565)
| Interesting article about mold by litigation. | gromicko | IAC2 Indoor Air Forum | 16 | 5/5/11 8:48 PM |
| Sump Pit/Pump Question | Joey D'Adamo | Plumbing Inspections | 4 | 11/26/08 2:04 PM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/21/07 12:56 AM |
