Old 5/12/11, 5:08 PM
Nick Gromicko's Avatar
Default InterNACHI releases Residential Code Inspection Exam Prep Flash Cards.
Nearly 200 Questions and Answers.
Find a Home Inspector
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/12/11, 11:38 PM
Default Re: InterNACHI releases Residential Code Inspection Exam Prep Flash Cards.
We're working on commercial inspection ones. The commercial inspection decks should be ready in a couple weeks.
Old 5/13/11, 9:24 AM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
I think these are very cool idea.
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 5/13/11, 9:40 AM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
This is a "Good Idea" but.... I already see a major mistake. I hope that you did not print out too many copies.
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 5/13/11, 10:53 AM
Frank, the question on one side of the card has the answer on the other side. The answer on the cards is the answer to the question on the back, upside down.
They are like that so that you don't see the answer unless you flip the card over.
Old 5/13/11, 4:48 PM
Hi Nick,
The "problem" has nothing to do with the "specific code", such as spacing, diameters, notches, square footage, nail spacing, electrical wiring, etc.
It has nothing to do with the composition of the "answer".
I have seen many a "builder" and inspector who knew every construction detail down to the smallest nuance fail the ICC test not because they did not know "the code" but because DURING THE TEST they could not find the correct chapter, paragraph and or page where the code was located.
  • I suggest that you look at the ICC "flash cards".
You will see that they not only asked the question and then gave you the answer but more importantly they also tell you where to find the code.
The bottom line is you can have the code memorized but if you can't locate it and quote "chapter, verse and paragraph" during the test you will not pass.
I hope this helps...
Fraudulent inspections wsiegel Florida Inspectors 40 5/10/11 8:12 PM
Advanced Residential Code Inspection Exam Flash Cards jlanger Miscellaneous Discussion for Inspectors 2 4/25/11 9:30 PM
Kansas Board Approves NAHI and ASHI Tests - Denies NACHI Test jbushart Legislation, Licensing & Legal Issues for Inspectors 29 2/22/09 5:15 PM
InterNACHI Beneifts jmckenna1 Miscellaneous Discussion for Inspectors 3 7/14/08 10:06 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
