Old 1/24/09, 4:51 PM
Bruce A. King's Avatar
Default Internet browser problem
I have not reinstalled Vista yet and was hoping someone would have a fix for me before I do that.
Dell laptop with Vista.
Connects to wireless network just fine but will not connect to the internet through that wireless connection. Windows says something is wrong with the IP address or router.
I have a wireless modem usb stick and that works just fine so its not just simply a corrupt browser.
As mentioned above, this is not a signal issue, it connects jjust fine to wireless signals, just want connect a browser to the actual intenet. On old PC's, this type of problem was related to a corrupt "winsock" file usually.
I did an online chat with a Dell hardware guy, he had me check a lot of things said the hardware was responding ok and the warranty did not cover anything else.
The problem with this type of symptom is that the internet is polluted with 15 million similar problem discussions and 99.9999 percent have nothing to do with this particular symptom which is weird to say the least.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 1/24/09, 4:53 PM
Michael Larson's Avatar
Default Re: Internet browser problem
This has happened to me several times and the solutions is almost always to reboot the wireless router. I have dlink.
I can reboot it from my desktop and after a minute is is fine again.
Never underestimate the difficulty of changing false beliefs by facts.[/I] - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Old 1/24/09, 5:17 PM
Dominic J. Maricic's Avatar
Dominic J. Maricic Dominic J. Maricic is offline
Send a message via ICQ to dmaricic Send a message via AIM to dmaricic Send a message via MSN to dmaricic Send a message via Yahoo to dmaricic
If your wireless usb stick works then the problem is corrupt drivers. Go to device manager and uninstall the drivers for your wireless card. Reconnect with your wireless usb stick and download the latest drivers from Dell's website for your wireless card (you'll need your serial number under the laptop or the back of the machine).
Post this kind of stuff in the computer section and I'll see it faster!
2008 InterNACHI Member and Innovator of the Year
HOME INSPECTOR PRO HOME INSPECTION SOFTWARE
NOW ONLY $499 ($15O OFF!!)
Easy to use, customizable Home Inspector Software that runs on Windows, Mac, Android & Linux
InterNACHI members receive 3 months of FREE home inspector website hosting
List yourself in our Home Inspector Directory Free
Watch our NACHI.TV Software & Search Engine Optimization videos!
Help@HomeInspectorPro.com
Old 1/24/09, 9:50 PM
Ok, just got done with that....
I deleted the wlan driver and installed a new one (same version).
Still same weird problem.....
I would have posted this in the computer section but it is limited to help from members only and many times non-members have good info too.
704 301-3207
Old 1/24/09, 9:53 PM
Did you reboot/reset your wireless router?
Does you computer detect your wireless network?
Michael Larson
Hudson, WI
Old 1/24/09, 10:03 PM
What model is the laptop?
Old 1/24/09, 10:06 PM
model PP29L better known as a Inspiron 1525
704 301-3207
Old 1/24/09, 10:09 PM
See original post, nothing to do with wireless signal, that works fine and connects fine.
Weird problem, no internet once connected to the wireless.
Same exact symptoms as a bad wireless signal but not that.
I am not actually on my own wireless system now and have another pc here that works fine on the wifi here.
704 301-3207
Old 1/24/09, 10:10 PM
Any chance you have it turned off? Does F2 have a little "A" on it showing wireless signal? If you hold the FN key and hit F2 it'll cycle the wireless on/off.
Old 1/24/09, 10:14 PM
It has a switch on the right edge, not that type of problem, I can receive and connect to the wifi fine.
704 301-3207
Old 1/24/09, 10:19 PM
Check your pm for a link to connect to me.
Old 1/24/09, 10:24 PM
I have a similar problem with my wife's Dell laptop. At the same time my wireless Q1 will be fine.
Hers connects to the wireless router fine but has limited connectivity as in no internet capability only local. The only thing that has ever worked is to reset the router.
Sounds very similar to your problem. Just trying to help. Good luck.
Michael Larson
Hudson, WI
Old 1/24/09, 10:29 PM
The difference Mike is that he has a usb wireless stick that he can connect with on the same machine. So more than likely his wireless card is blown or it's a driver issue.
Old 1/24/09, 10:35 PM
Gotcha. My wife's drove me nuts a number of times.
Here's would show limited connectivity and not function until I reset the router or sometimes reboot her laptop.
It's a prowireless in her laptop.
Good luck figuring it out
Michael Larson
Hudson, WI
Old 1/24/09, 11:30 PM
Dom logged into my pc and checked some things, tried it again, still same problem.
He gave me some ideas to try and I'll report back tomorrow
704 301-3207
furnace problem ? Aaron lore General Inspection Discussion 11 2/5/09 1:04 PM
I have a problem cbottger Electrical Inspections 17 1/20/09 4:45 PM
Try a different browser sstanczyk Miscellaneous Discussion for Inspectors 6 1/3/06 4:23 PM
