Old 9/15/07, 11:24 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Default IR Makes Hot Pipe In Slab Visible
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 9/16/07, 12:01 AM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: IR Makes Hot Pipe In Slab Visible
Oh man, I can't wait for my class !!!
Mic
Old 9/16/07, 12:31 AM
When are you going for training Mickey?
Old 9/16/07, 5:48 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
John, is this new construction? I can't tell from the photo, is this the garage floor? Looks like somebody made a big boo-boo, didn't they.
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 9/16/07, 6:41 AM
ldapkus ldapkus is offline
Originally Posted by jmckenna1
I've got an a contractor that is building a home with radiant heat under his hardwood floors. I demonstrated how my BCam works when I was doing a draw inspection not long ago. He is no longer wondering how he is going to install floor outlets without cutting into the water lines. He's got my card and will be calling shortly.
Old 9/16/07, 8:53 AM
Charley L. Bottger's Avatar
Way to go Linas If I find some one standing still and are still breathing I demo the camera Folks that have not seen one are just absolutely facinated with what it can do. I even took mine to my barber shop while getting a haircut.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/16/07, 8:59 AM
jrivera's Avatar
Bldg Sci.,November in Boston
Mic
Old 9/16/07, 9:08 AM
Mic
It's a great course. Pay attention Mic!!
Old 9/16/07, 2:23 PM
jrivera's Avatar
Thanks, I got my camera sometime in bet. you and John, but this was the best time for me to take the class.
I'm putzing around with it, but it gets frustrating knowing that I'm just putzin'.
I've got Wills' CD and I took that on-line course that Flir had, but I can't wait to get the real thing under my belt.
Mic
Old 9/17/07, 7:42 AM
Peter C. Russell's Avatar
Here's one I did of a new 3800 square foot home, no access to the attic and when I scanned the walls and ceiling I found an entire bay missing insulation.
Old 9/17/07, 8:15 PM
Here's a shot of an insulation gap in a cathedral ceiling during today's inspection:
ID:	14572   ir-makes-hot-pipe-slab-visible-p9170042-small-.jpg.JPG
Old 9/17/07, 9:33 PM
And here is one of mine which is bigger all along a north wall after I had a look in the attic it appear that some one had raked the insulation back from the soffit vents in this area.
The second pic is a take off from the plenum large air leak where the duct connected.
The third was a breaker in the garage panel registered 126 ddegrees
NACHI Member
State License # 130
Old 9/17/07, 9:38 PM
Linus I notice your Emmisivity set on 85 on sheetrock any reason for that.
NACHI Member
State License # 130
Old 9/17/07, 10:15 PM
William J. Decker's Avatar
Be very careful in calling out exact temps unless you specifically adjust the camera to the emisivity of the material. Bakalite has a very high emisivity.
Remember, Delta T is more important than an actual measurement. Use a contact thermo or IR thermometer. Much quicker.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 9/17/07, 10:37 PM
I did Will also checked with the IT Thermo both very close in temp. At this stage of my learning I don't call out any thing with the Cam unless I have backed it up visually or with another test device.
I like to change the emisivity on different types of material just to see what the difference in range actually is. I am still at the play stage with the cam.
NACHI Member
State License # 130
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
