I am having difficulty viewing video, because of javascript not being enabled. Not even sure if I have it, unable to locate. Please advise.
Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Go to Java site and download for free
Gary,
One easy way if you are running Winders: 1. Start 2. Control Panel 3. Add/Remove Programs Check to see if you have the java Run Time Environment installed. Not sure what browser you use? Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
Emmanual
I have java 2 run time. Where would I see if its enabled? We have internet explorer as our web browser. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Not E man ..but try going to tools -click internet options at the bottom then go to security.
Once at security click internet and go down the list to check that java is enabled. |
Gary,
Robert's got you set. Also depending on your browser and JAVA version go to "Tools" and click on the "Advanced" tab. There might also be an option there that requires checking. If you are running current versions of SUN's JAVA plug in, once done there go to "Tools" and you may have a "SUN JAVA Console" selection. The console will provide you with a status printout. If it is SUN JAVA you will see that it is initializing correctly or what errors may be occurring. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
Gary,
One more thing. You can also go to http://www.java.com/en/download/help/testvm.xml . If your JAVA plug in is installed and working properly it will test and report on it just by accessing this page. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
I don't think you guys are talking about the same thing, javascript is not java. Javascript is the scripting language which runs on web pages in the browser. I don't use IE, so I don't know where the settings are for it, but javascript has nothing to do with java (except the first for letters of its name).
-- bz Brian Zimbelman Circle Z Inspection Services http://www.circlezinspections.com 575-535-4481 (wk) 575-313-1281 (cell) |
For a browser to run a JAVA applet you will need the JAVA Run Time Environment (JRE) properly installed and activated. The steps we are running through are ensuring the JRE is present and properly activated in the browser. Unfortunately MicroScrew does not make things as simple as they originally claimed they would (originally as in post MSDOS). Another nice feature of FireFox is the actual simplicity of install, updating and plug-in adding. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
7 replies before the first person stated the ovivous. The OP said javascript, not java. However, I've heard nothing else important asked, just a bunch of EXPERTS spouting off stuff.
What browser are you using? What is the error message? What OS are you using? Is this a recognized source of movies(YouTube, etc.)? Nice you being Phished. tom |
So are you saying that to run a JAVA applet you do not need the JAVA Run time environment installed as a plugin to the browser? Please enlighten us to how JAVA functions. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
I'm saying, where did Gary say he had a JAVA error?
Rather than getting into a pissing contest with geeks, my post was for Gary. tom |
If your post was for Gary then why the attack on other members trying to help Gary? As for Gary's original issue post I will place it here so that you do not have to scroll up. Gary Schering wrote: Quote:
As for slinging names, do you really feel a need to berate others trying to help a fellow member? Can you shed some light into why you feel that need? Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
