Hi To all,
Rick Bunzel wrote this article which appeared on The Inspectors Journal site, he was kind enough to allow me to republish it here, in the light of accidents befallen to 2 of our members recently, we should all read this carefully. Thanks Rick Most of us believe that an accident during an inspection will never happen to us. However think back over the past months as to how many close calls you have had? How many times has the ladder jumped around while we were going into the attic? Or when the ladder shifts when you’re stepping back onto your roof ladder?Portable ladders are one of the handiest, simplest tools we use. Because of their simplicity we use them without a lot of thought. Each year in the U.S., accidents involving ladders cause an estimated 300 deaths and 130,000 injuries requiring emergency medical attention. As a fireman and a home inspector, I use ladders on a regular basis and it is easy to take them for granted. I have deliberate steps I take every time I set my ladder up to maintain my safety. The majority of ladder accidents are caused by improper selection and use. Some of the more common hazards involving ladders, such as instability, electrical shock, and falls, can be easily prevented. Prevention requires proper planning, correct ladder selection, safe work procedures. Always look at where you are going to use your ladder. I look for trees obstacles. The ground where you are raising the ladder should be relatively flat and offer good traction to the ladder feet. If you are raising an extension or multi-purpose ladder to the roof, always try to extend it at least 3 feet above the roof edge. Make sure the ladder extension locks or dogs are locked and tie the rope around the rungs. On multipurpose ladders the locks should be engaged. The foot of the ladder should be spaced 1 foot away for every 4 feet it reaches up. An easy way to check the angle is to stand with your feet against the base of the ladder and extend your arms toward the ladder. If you have the correct angle, your hands should easily grasp the rungs. If it is a windy day take a bungee cord with you and wrap the bungee around the top rungs and attach to the gutter. This ensures a strong gust won’t blow down your ladder. Three points of contact is the rule for climbing or descending a ladder. Hold on with both hands when going up or down. If the client or realtor is available have them steady the ladder while you are on it. Check the soles of your shoes before climbing. Mud or debris can turn into a lubricant at the wrong time. If you have to climb a steep roof, use the valleys, as they seem to offer a better surface for climbing and descending. I wear mechanics gloves during roof and crawl space inspections. On a hot day the shingles and flashing are 130+ degrees. I learned this the hard way one when I was getting back onto my ladder and put my hand down on a shingle. That was the last time I went up without gloves! Seven Tips For Ladder Safety:
Lastly, if you are going to work on your roof, beware of the pitch or angle of the roof. It is always easier to walk up the roof than down it. I never walk on metal, tile or slate roofs and rarely on wood shake roof. I also rarely will walk on a wet or snowy roof. Those surfaces offer questionable traction and if I run into a problem I want all the traction I call get. This is my personal preface, which I am sure some people will disagree with but I back it up with 30 years experience as a firefighter. As a firefighter we use ladders in all types of conditions and only take risks when lives are on the line. We train with safety in mind to minimize the risks.If the roof looks pretty steep when you get to the top of your ladder, then it may not be safe for you. If your nervous and your body is sending out danger signals, then exercise your right to call the climb unsafe for you. It’s better to say no than to risk getting hurt or killed. In 2004, Rich Norris, a home inspector in San Diego fell off a roof and died from his injuries. I sustained an injury falling off my own gazebo last spring. I fell 15 ft. to a wooden deck and couldn’t work for 2 weeks. I was lucky; I didn’t break any bones and only separated a shoulder. When you own your own business and can’t work, your income stops. The bottom line is don’t take unnecessary chances. Be safe! ![]() Rick Bunzel is the Principle Inspector at Pacific Crest Inspections and a Firefighter with the Mt. Erie Fire Department Rick can be contacted at Pacific Crest Inspections @ 360-588-6956 or Rick@PacCrestInspections.com. For discussions about other inspection-related topics on TIJ's Other Forums. "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 3/6/06 at 9:58 AM.. |
Thanks Rick
I walked 8" I Beams 100 feet off the ground in my younger days. What looked like highways on the ground became toothpicks 100' up. I guess the fear of the sudden impact at the bottom has stayed with me all these years. I stay vigilant in being carefull at all times. I'm with Greg.....
Thanks for the "Heads Up", it always helps to be reminded over and over again. |
Thanks Gerry and Rick for the reminder about ladder safety. Inspection of roofs and electric components are two areas where inspectors have to be extremely careful ...
Here is a cut-and-paste version you can refer to occasionally ... ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 3/6/06 at 6:41 PM.. |
I used to walk steel bar joist when they were not welded, and thought that was fun. Now I won't walk them welded.
How times will change perspective in life! Thanks to you all for the reminders that people do not hear often enough. Marcel |
tbrown1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Rick:
Great tips for our safety on ladders. I especially liked the bungee cord idea for windy days. I'll be using that tactic in the future, I promise! Thanks for thinking about the safety of all of us! Tim Brown, AAHI Inc. |
In high school I laid out in the sun on the top of a tri-level roof. Dumb and a quick burn
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
very nice
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Several years ago I did the old "ladder pull-up" to access the second story roof. As I was hauling myself up onto the roof my foot brushed the ladder, sending it crashing down into the yard. Of course, no one was home at the time. I spent a lovely hour trapped on the roof contemplating just how foolish that move was. Never again.
Thanks for the posts guys. "A man cannot be truly grateful and remain unhappy"
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
dmcauley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Having spent 24 years as a career firefighter, mostly on a ladder truck, and part time construction for those years ladders can be dangerous. One thing that everyone should do prior to extending the ladder is to look up to see what is above the ladder. This little maneuver saved me from electric wire contact many times. Always be safe and do not overextend your self on it. go no farther that the wing span of your arms! Be safe!
| Home Inspection IS NOT ABOUT SAFETY | jcahill | General Inspection Discussion | 39 | 2/26/07 12:08 AM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 2:14 PM |
| Home Safety | jbushart | General Inspection Discussion | 0 | 10/23/06 8:17 PM |
| Ladder Safety from ITA | badair | General Inspection Discussion | 4 | 8/9/06 7:59 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 2:48 AM |
