Old 11/9/07, 1:10 PM
Charley L. Bottger's Avatar
Default The learning process IR
No I am not teaching IR am not qualified but would like to pass on some info to the guys that are considering taking the class. My instructor was the Senior FLIR Level 3 instructor and he emphasized the importance many times of placement of the Spot which I call the bullseye on the camera screen. He stated that if you are looking for Temperature not just a image such as on a breaker, Motor Bearing, Electrical wiring and such that the Subject must fill the Spot. Would make no difference if viewing a wall cavity void of insulation or a water leak in the wall. I have posted a couple of images one of my grandsons cold noise just came in from outside. The other two are of an air leak on a door note the temp difference in the bullseye by simply placing the spot less than one inch to the right of the other image. Distance from your target is very important fill the spot to get the correct temperature.
I use this type of image in my marketing approach to clients show a temp difference in numbers such as in mine 50 degree air coming into a 67 degree room is a lot more impressive than showing a Red and blue image with your image showing very little to no Delta T Just my thoughts
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/9/07, 2:39 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Default Re: The learning process IR
Good marketing point.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 11/9/07, 8:45 PM
Good info, Charley...thanks.
Larry Kage, CMI
231 929 3525
Old 11/9/07, 8:51 PM
Roy D. Cooke, Sr's Avatar
Thanks every one for your posts I read and reread them all.
My FLIR camera is on its way and I should get it Monday.
Signed up for level one Dec 4th With my buddy Mario.
Every one is a great help and I appreciate it all thanks
.......... Cookie
Old 11/9/07, 9:01 PM
ldapkus ldapkus is offline
Here's a link to the latest ITC Newsletter:
http://www.itcnewsletter.com/2007/2007-11.htm
Old 11/9/07, 9:03 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Thanks Linas!!
You are allways very helpful!!
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 11/9/07, 9:10 PM
Originally Posted by mkyriacou
Thanks Linas!!
Not Always. I tend to be a smartass at times.
Old 11/9/07, 9:16 PM
William J. Decker's Avatar
And you do it SOOOO well
From one "smart butt" to another (Take that, you automated obsenity checker, you!).
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 11/10/07, 7:00 PM
David A. Andersen's Avatar
Check out the roof article.
CMI/NACHI/IAC2 approved distance learning course on Central Air Conditioning. gromicko Inspection Education & Training 0 7/24/07 12:18 PM
The Learning Channel mreusch Miscellaneous Discussion for Inspectors 8 8/22/06 12:55 PM
Ontario PDI Process, Need some help. mferro Canadian Inspectors 2 6/29/06 12:33 PM
