Old 12/31/07, 6:23 PM
Barry Adair's Avatar
Default Microwave oven testing?
Please no lectures on SOP, liability or...
Are you aware of a standardized test for residential microwave oven equipment?
AHS is refusing another clients request for repair.
What test method do you use?
Here's what I have from some manuals:
Please check the following before calling for service:
1. Place one cup of water in a glass measuring cup in the microwave oven and close the door securely.
Operate the microwave oven for one minute at HIGH 100%.
A Does the microwave oven light come on? YES _____ NO _____
B Does the cooling fan work? YES _____ NO _____
(Put your hand over the rear ventilating openings.)
C Does the turntable rotate? YES _____ NO _____
(It is normal for the turntable to turn in either direction.)
D Is the water in the microwave oven warm? YES _____ NO _____
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/31/07, 6:27 PM
David P. Valley's Avatar
Default Re: Microwave oven testing?
I DO NOT inspect portable appliances and my agreement states that. Only built-in appliances such as Stoves, Wall Ovens, Dishwashers, etc.
If it can be moved, it's not inspected.
Old 12/31/07, 7:03 PM
Michael R. Boyett's Avatar
Barry,
95% of the microwave ovens I encounter are built-in and usually include the range hood and stove light. I use Mr. Microwave Magic Lights for $6 ea from http://www.electronix.com/catalog/pr...oducts_id/5445
Old 12/31/07, 7:06 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
http://www.nachi.org/microwaveovenleakdetectors2006.htm
and
http://www.nachi.org/tribbles.htm
Find a Home Inspector
Old 12/31/07, 7:29 PM
Jeffrey R. Pope's Avatar
I use a device similar to Mike's and Nick's - a microwave leak detector.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/31/07, 9:53 PM
tdietrich1's Avatar
The tribbles actually exist?
Old 12/31/07, 10:04 PM
InterNACHI member Phil Gage's wife makes them for us. We've shipped many thousands of them over the past 2 years.
Old 12/31/07, 11:34 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
A hamster wrapped in electrical tape on high for 3.5 minutes. If it cooks without exploding it passes.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 12/31/07, 11:42 PM
Dang it Manny!, now everyone knows the secret to making the tribbles: http://www.nachi.org/tribbles.htm
Old 1/1/08, 12:19 AM
Nick,
I've tried the Tribbles but when you miss lunch they don't taste so good warm! Now hamsters with a dash of Tobasco, Ummm Yummy!!
Actually send me some tribbles. Do these cost much to make with the NACHI logo on them? They would make great ice breakers when giving presentations or speaking in groups, etc.
TREC License# 7593
Old 1/1/08, 9:57 AM
Tribbles and blinking lights do not tell the client anything about measurable heating whether the unit is or is not functioning properly. Not like setting an oven a 350°F
I've always said a cup of tap water for 1 minute at high should be at least 120°F otherwise just wait for the sink supply in most homes.
I also carry microwave popcorn and will pop a bag for function and snacking on vacant properties and will ask permission on occupied.
The issue on this one instance is a $900.00 unit that requires repair or replacement and the warranty co. does not want to honor their agreement. I was just curious what test methods were used by others.
HNY BTW
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 1/1/08, 10:07 AM
Michael Larson's Avatar
Barry,
For the most part a microwave oven is either on or off. No in between.
Power levels are manipulated by percentage of on vs. off time for most microwaves.
You can read all about it HERE
Here is an INDEX
IMHO, if it blinks the tester lights, heats the tribble or pops the popcorn it's working as far as an HI is concerned.
Have a great New Year of 2008
Old 1/1/08, 10:09 AM
Warranty co. says my 1 minute test along with the NACHI light tester is inferior and should be tested on high for 2 1/2 minutes this should boil water 212°F in most units
Unit in question will only get to 200°F by their own time and test,
"but that is close enough" they say.
Glad I don't have to eat their cooking
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 1/1/08, 10:25 AM
Barry,
How hot the water gets after 2 1/2 minutes depends on:
the starting temp of the water
the power output of the microwave
Power level setting of the microwave
I have had both low and high power microwaves.
Perhaps your client is just used to a different type of unit.
It takes some getting used to going between the units.
I have the same problem between my travel trailer and the house. They do not act the same.
Find out the mfg. rating for the microwave in question.
Old 3/11/09, 12:27 PM
mnahrgang's Avatar
What are these things filled with? I was using mine yesterday and it started to pop like a bag of popcorn. Smelled like it too.
Mark Nahrgang
www.HeyMark.info
Coming soon: New LED-style microwave oven leak detectors. gromicko Miscellaneous Discussion for Inspectors 22 6/29/10 7:55 AM
Microwave testing psiposs Electrical Inspections 18 8/29/07 8:25 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Order your free NACHI Tribble (microwave oven tester). gromicko Miscellaneous Discussion for Inspectors 14 9/30/06 12:48 PM
FREE Microwave oven leak detectors. Order yours now. gromicko Special Discounts for InterNACHI Inspectors 13 5/20/06 3:57 PM
