Go Back   InterNACHI Message Board > General > Misc. Discussion
Misc. Discussion Discuss whatever you wish in this forum.
Old 6/18/09, 3:10 PM
Default Moisture Meter?
I am in the market for a moisture meter, but am a little baffled by the range of choices. I am seeing digital 'pin-type' meters that cost less than $50 all the way up to models that cost many hundreds of $$. So the question is, 'what is the real difference', if what I need to do is measure the moisture levels in a home I am inspecting? Knowing that more expensive is not always the most cost-effective, I'd appreciate some input. TIA
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America)
Old 6/19/09, 7:06 PM
Default Re: Moisture Meter?
Spend as little as possible............
Old 6/19/09, 7:39 PM
Nick Gromicko's Avatar
Protimeter or Wagner make the best ones IMHO. Both are mid 300's, so don't leave them on an inspection. Wagner deal at: http://inspectoroutlet.com/tools-IR-...nd-Meters.aspx
Nick Gromicko, CMI
Founder
World's biggest, best inspection association
"Planet InterNACHI... resistance is futile"
Old 6/19/09, 9:23 PM
John McKenna's Avatar
John McKenna John McKenna is offline
A dual function gives you the double witness and helps you
reduce the chance for false positives.
http://www.professionalequipment.com...uctive-meters/
Old 6/19/09, 10:08 PM
So what makes the $300 + meters better than some costing 1/2 of that or less? That's what I am trying to understand.
Frank P. Newman
Dublin, GA
Old 6/19/09, 10:31 PM
David A. Andersen's Avatar
Depth of detection.
ITC Certified Level II Thermographer Cert#1958
Old 6/19/09, 11:03 PM
Joe Funderburk, CMI's Avatar
I like the Survey Master. It does it all. Great for crawl spaces...the pins let it stick in the wood while you hold the light with one hand and snap a photo with the other. The pinless types, like the Tramex, don't work well in tight areas like between floor joists. And a slim detector like the Protimeter works well in a coverall shirt pocket in a crawl space. It also is non-destructive...allows you to test shower walls, tile floors beside toilets, etc.
The Surveymaster cost is a bit high. Shop around. I bought mine used. Check eBay.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/20/09, 10:38 PM
Let me play devils advocate.....
You see a water stain on drywall.....(or wood floor around toilet).......how much do you really need to spend before you decide if its a previous stain or new.
Drywall is 1/2 thick....5/8 on fire rated............. so tell me.......how much do you want spend before determine that moisture is present......$75.00........$750.00?
You can spend $20,000.00 on the best equipment for your tool bag.....or spend 1/2 that and produce the same results......except with extra money in your pocket for more classes (Im sure Nick and Ben don't mind that) and marketing.
I like looking through the Professional Equipment like most inspectors......but when all is said and done I know its not the equipment that makes the inspector but rather the inspector with savy knowledge who knows how to work with what he has at the time.
Old 6/20/09, 11:37 PM
I agree - that's why I trying to get some realistic information about what the real difference between the various offerrings is. Any catalog you want to open will have as many as 10+ models. They can't all perform the same or give the same quality of information for the inspector to consider, yet there does not appear to be any quantitative infomation to allow a meaningful comparison.
Yes Joe, I will definitely look for a resale on eBay or elsewhere.
Thanks
Frank P. Newman
Dublin, GA
Old 6/20/09, 11:41 PM
Originally Posted by dandersen View Post
Depth of detection.
OK - now that appears to be a quantitative measure for comparison. So how deep does a home inspector really need to look and why? Also, I don't see that spec list for many of the meters sold.
Frank P. Newman
Dublin, GA
Old 6/21/09, 1:02 AM
William E. Siegel William E. Siegel is online now
Try going to a Harbor Freight, if you have one in your neighborhood, or go on line to their web site.
Bill Siegel
Florida Home Inspection Team Inc.
Old 6/21/09, 8:44 AM
Linas I. Dapkus's Avatar
Linas I. Dapkus Linas I. Dapkus is online now
One of these should do the trick!
Old 6/21/09, 9:33 AM
John Evans John Evans is online now
The Protimeter Surveymaster is expensive but very effective and easy to use. The dual function (pinless & pin) feature, plug in extended pins, optional EIFS pins and self calibration features makes the cost worthwhile in my opinion. Of course, you may find comprable units, I have used the Protimeter for about 4 years. Shop for better prices.
Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
moisture meter jharrison General Inspection Discussion 0 5/23/09 8:56 PM
Moisture Management mcyr Exterior 15 9/8/08 1:11 PM
Moisture in slabs mcyr Structural 7 8/20/07 8:33 PM
bbbb mcyr Structural 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
