Hey folks,
What do you recommend for a general purpose HI moisture meter? TIA, Tim |
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
Delmhorst.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Fluke Ti32
---- Hi Tim...actually I use the Protimeter Mini...which also has an an extension cord with pins for close-or far locations...nice meter! If your looking for non evasive that is...but, actually just touching it to a surface without probing will give you a good reading. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I use the protimeter aquant Tim...
Wow. That was a broad spectrum to choose from. I guess it's not like the
Suretest that everyone seems to have (and send back) Cheers, Tim |
Protimeter or Wagner IMHO.
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not cheap but worth the price. Make sure you shop as prices do range all over the board. |
I am a generalist inspector and I want a generalist meter, besides, I like em' cheap.
Lignomat Mini Ligno S/D Moisture Meter The Mini Ligno S/D is Designed for wood and "soft" building materials, such as drywall, plaster and roofing, etc. Even though the mini-Ligno S/D is on of the least ex-pensive meters, it is built with the same high quality components as the more expensive meters. It just doesn't have as many features. The green cap covers the pins for safe transportation. To obtain moisture readings, the pins are pushed into the material and the unique on-off switch between the pins turns the meter on. Bright LED lights instantly indicate the moisture percentage. A popular, easy-to-use instrument. The mini-Ligno is the right choice for you, if the range, the read-out accuracy and the basic two-group settings for different species are sufficient. - Measuring range 6-20% for Wood, 1 Setting for species corrections - Colored lights indicate wet, moist or dry condtions for building materials "A state of war only serves as an excuse for domestic tyranny." ~ Alexander Solzhenitsyn Certified Master Inspector (2007) Member, International Assoc of Certified Home Inspectors (InterNACHI) Member, International Code Council (ICC) - Certified Residential Combination Inspector Square-One Inspection "Assurance begins here"
No matter which brand you choose, I'd strongly recommend one that is non-destructive AND has pins. The pins come in very handy in areas like crawl spaces, where you can let them hang from the wood while you use one hand to hold a light and the other to snap a photo. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Thanks, all.
Tim |
| Fighting Mold — The Homeowners' Guide from CMHC | mkyriacou | IAC2 Indoor Air Forum | 1 | 9/17/09 2:32 PM |
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
