House just down the street from me. Built about 3 years ago and never sold.
Name that defect! Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
would you mean the lack of counter Flashing?
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Window is too close to roof. there is a minimum distance that a window sill has to be above a roof, and this does not meet that criteria. Also looks like flashing is not tucked under wall brick, but i can't tell from the picture. No kick out
Yes all sorts of flashing issues.
Add lack of kickout and no sill flashing. May I poo poo Florida style casements just ...because. On netbook ,but is that EIFS? Will my concern with the window would also be if a bar is required as it appears(love the word) that it may need a safety bar if it is low as it looks on those stairs. |
What do you guys mean with, no kick out? I don't see flashing behind any siding so there is no where to kick out from.
Good thing that any water that runs behind the step flashing (because of the lack of counter flashing) runs down and is still out side. May not do that first rafter and the roof sheathing any good though. Benchmark Home Inspection Services. http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas. |
Built on Decker's street. Property values in steep decline.
You know I'm just funnin ya' Will. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Yep. Let's see what else we can find, shall we?
What's with the crack in the stucco/EIFS in the window?
FYI. The original builder tried to get out of the project by attempted arson, but had to finish the house because of the contract. He is currently under house arrest. House moved into recievership and has been rented twice, but never sold. In this area, every house has a story. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Very good, Jae. It is a crack. you have good eyes
Seriously, stucco installed directly on the dimond mesh that was stapled to the tyvek / OSB underneath. Typical around here. Everyone relies too much on the Synergy coating. Go figure Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Oh, not pictured, but just icing on the cake. Bottom portion is split faced block.
I HIT THE JACKPOT WITH THIS ONE! Nick should buy it as a haunted house! Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Fused panels, automatic defect, upgrade, or what? | cnagy | Electrical Inspections | 2 | 1/30/10 12:13 PM |
| Name that defect? Care to play? | wdecker | Electrical Inspections | 22 | 9/13/09 9:21 AM |
