Old 8/13/08, 10:11 AM
dcallahan dcallahan is offline
Please Note: dcallahan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Need help fast
I did an inspection yesterday where the basement has been remodeled. The new hook ups for the washer and dryer (electric) are now on an interior wall oppisite where the old dryer vents to the exterior (approx 20 feet). All walls and ceiling are newly drywalled, textured and painted. My question (probably just brain freeze on my part) is does an electric clothes dryer have to be vented to the exterior?
Old 8/13/08, 10:26 AM
James E. Braun, CMI's Avatar
Default Re: Need help fast
Yes, because the dryer vent will put out a lot of moist air. I can tell you some sad stories about improperly vented dryers and drywall.
Old 8/13/08, 10:38 AM
klott's Avatar
klott klott is offline
Absolutely, the dryer has to have a way to remove all the water from the wet clothes,and then send it outside. For it to travel that far, it needs to be rigid pipe with a minimum of bends to be efficient. Gas dryers have to vent the by products from the burner also.
Old 8/13/08, 10:39 AM
Bob Elliott's Avatar
Unless it is a condensing unit.
Old 8/13/08, 10:45 AM
Thank you for the quick answers. I was baffled to see all this money spent on the basement remodel that will now have to be torn apart to make the dryer vent right. They also carpeted the laundry area without installing a drain pan.
Old 8/13/08, 4:24 PM
Charles L. Harper's Avatar
Charles L. Harper Charles L. Harper is offline
SECTION M1502
CLOTHES DRYER EXHAUST
M1502.1 General.
Dryer exhaust systems shall be independent
of all other systems, and shall convey the moisture to the
outdoors.
How fast can you climb a ladder? mjones6 Miscellaneous Discussion for Inspectors 13 5/13/08 1:12 AM
