Old 8/2/07, 3:13 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
Default need opoinions /advice
put in a concrete drive way approx 6 years ago at my house, suffice to say it is now in bad shape, I would like to overlay with hot top is this a good idea or is it better to tear it out & start over thanks in advance
Old 8/2/07, 3:20 PM
Peter C. Russell's Avatar
Default Re: need opoinions /advice
Dennis, I would think you would have to remove it. My thought is if water gets in there and freezes it will heave the new asphalt and crack it.
Old 8/2/07, 5:03 PM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Hi Dennis,
A concrete driveway should have lasted you for many, many years. Sounds to me like the "base" was not stable enough, deep enough, compacted enough, or too much "expansive soil" was in the base instead of rocks and or compacted gravel.
This situation will have to be corrected/rectified or you will just have another unstable driveway on your hands. Giving unstable concrete a coating of asphalt will only exacerbate the situation and it will be money thrown down the drain.
My recommendation is complete removal of the concrete, and having a good four to 6 inches of rock/gravel compacted into a nice tight firm base.
If you decide to re-install concrete have a minimum of 3,000 PSI, 4 inches thick, with the appropriate welded wire mesh in the concrete.
Good luck!
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
