By Barry Stone
http://www.dailyherald.com/story/?id=148638&src=118 Q. I purchased a brand new home -- a bank-owned, "as-is" property. On the day of the home inspection, there was no hot water because the bank refused to turn on the gas service. Because of this, the home inspector did not discover that the upstairs bathrooms were piped with hot water only. So now I can't use the tubs or showers because the water is scalding hot. Our plumber says there is a cross-connection of the hot and cold water lines somewhere in the building and that it will be difficult to find where the problem is. I can't afford to re-pipe the house and don't know what else to do. What do you advise? A. Your house probably does not need to be re-piped, but some investigative work will be needed to determine where the faulty pipe connections are located. To do this, some of the drywall will need to be removed to enable inspection and evaluation of the pipe layout. You should consult with your plumber to determine the least intrusive way to approach this process. At the time of the home inspection, this problem could have been discovered, even without gas service or hot water. Your home inspector could have turned off the supply valve at the water heater. This is how home inspectors verify that faucets have cold on the right side and hot on the left when the gas service is off. Had your home inspector done this, he would have discovered the lack of cold water plumbing in the upstairs bathrooms. John McKenna, CMI (TREC #4565)
At the time of the home inspection, this problem could have been discovered, even without gas service or hot water. Your home inspector could have turned off the supply valve at the water heater. This is how home inspectors verify that faucets have cold on the right side and hot on the left when the gas service is off. Had your home inspector done this, he would have discovered the lack of cold water plumbing in the upstairs bathrooms.[/quote]
Sorry, I dont open or close any valves, so I guess I am the poor inspector who would have missed this. HMMM Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Troy , that was my exact thought .
Same thought!!!!!!
I also do not open any main shut off valves in the basement .
Three time agents have told me to not be so silly and they have opened them and three times there was water where it should not be. ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
In the report will go a disclaimer.
Bank should make the repairs if not dis-closed. Just my thoughts. |
It would interesting to know how many inspectors actually do open and close valves I bet its high. so would the liability. (agents and buyers just don't understand why we don't, even after we explain it to them).
Heck just the other day a Realtor was peeved that I couldn't check the sprinkler system I tried to explain it to her but I don't think she got it. Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Perhaps you could explain the definition "Liability"
"the state of being legally obliged and responsible".
Oh my I just opened that valve, I knew I wasn't suppose to, but the Realtor was pressuring to get the inspection done, so I did, low and behold there is water everywhere running down the wall spraying everywhere now who do you think is responsible??? me or the Realtor? I am not willing to assume that kind of liability. Then comes the attorney he thinks is this gross negligence oh man look out. Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Banks are exempt from disclosure rules.
It makes sense, they never lived in the house. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I'll open any valve(faucet) that has a sink, tub or shower pan underneath it..otherwise....no way....I can't count the number of times as a contractor I closed a valve to work on something only to have it start leaking at the shaft seal packing...of course then You put a wrench to the packing nut and You may just get a shower....
If you read it again, it does not say to turn ON a valve. It says turn OFF the
valve to the water heater (long enough for the test). If it is already ON, why would it hurt to turn it off for this simple test.? Your not going to flood anything by turning it off. Quote:
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 3/9/08 at 5:53 PM.. |
Again who is responsible if it breaks? its always the what if's that get us in trouble.
Trust me I understand that the likely hood of something happening is rare but again what if?? Thats all Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
No lawsuits as of yet but it does add 30 - 45 min to the inspection (carefully checking and documenting all visible supply lines) Do I fault any inspector that does not turn a main water supply on or off? Hell no ... to each their own. |
If there is a cross connect between the hot and cold then if the hot is shut off at source the water should get cold. If it was all cold to begin with the cross connect would have made it impossible to judge there was any kind of problem. So much about this doesn't make sense. It sounds like the client is being taken for a ride. Has anyone ever heard of a plumber forgetting to run cold water lines? Oops! I think they need another opinion. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| Buyers Best Home Inspections | ddinwoodie | Miscellaneous Discussion for Inspectors | 6 | 9/4/06 7:20 PM |
