Old 6/25/09, 12:18 AM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default No Main Disconnect
This is a panel in a condo in Chicago. There is no main shut off, there are no other panels in the condo. What do you guys think? I am thinking that the main shutoff is in the electrical closet in the outside hallway, which I did not have access to because there was no staff authorized to allow me access.
Also, the circled area, seems to be the ground wire. Shouldn't that be connected to the neutral bus? Is this a way of bonding?
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America)
Old 6/25/09, 6:24 AM
David P. Valley's Avatar
Default Re: No Main Disconnect
Michael,
This is a typical (LSE) sub panel. The main SE breaker (shut-off) is located in a mechanical room at the main floor or basement of the building.
Simply note "No access to Main SE panel".
Where are the ground wires?
Old 6/25/09, 6:30 AM
Joseph Burkeson, CMI's Avatar
Joseph Burkeson, CMI Joseph Burkeson, CMI is online now
Wired in metal conduit.
"A state of war only serves as an excuse for domestic tyranny." ~ Alexander Solzhenitsyn
Certified Master Inspector (2007)
Member, International Assoc of Certified Home Inspectors (InterNACHI)
Member, International Code Council (ICC) - Certified Residential Combination Inspector
Square-One Inspection "Assurance begins here"
Old 6/25/09, 6:32 AM
Where do you see BX?
Old 6/25/09, 8:30 AM
EMT serves as ground
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 6/25/09, 8:35 AM
Bob Elliott's Avatar
Never assume Mike ,but I am going to stick out my neck and say your main panel is in the meter room.
I do not know the layout ,but remember to always follow the mast and try to get in to the locked room where it enters the buiding if not in a hall closet.
Small buildings it will be ground floor.
Mike the conduit serves as ground and the green wire is most likely for a spa tub.(guess)Reason is you have gas powered appliances.
How do I know? (only one double) (for HVAC)
Ground wire and the box should be connected but separate from the neutral bar.(look for a green screw or small bracket which bonds the box to the neutral bars which would be incorrect)
I see no problem from the picture.(If this is a new Condo please do call out lack of AFCI for the bedroom)
Will show you the flat head screwdriver trick (just kidding).
Old 6/25/09, 1:24 PM
As stated in my first post, there is an electrical room about 2 doors down from the unit. No one at the building could give me access. I did not see the bond screw, I thought that the circled item in the pic was a type of bonding. I read on the board that sometimes the screws that are used to install the bus bars act as the bond.
No spa tub or whirlpool.
This is an older building, I think it is the Millenium Building. It seems to me that the unit owner should have a way to shut off all electric to the unit.
I did tell the client about AFCI, and since he is going to have an electrician fix some receptacles, I suggested that he ask the electrician about installing AFCI.
Michael Merino
Old 6/25/09, 1:27 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think the idea is that, in an emergency, the power can be shut off to multiple units much quicker than going unit by unit, seeing if people are home.
And they do - they should have access to the electrical room.
Not much different than having the main breaker at the meter.
Old 6/25/09, 1:39 PM
I am an idiot! Don't everyone agree to quick.
#1 rule-NO bonding in a sub-panel!! No wonder I didn't see it.
Michael Merino
Old 6/25/09, 1:54 PM
Jeffrey R. Pope's Avatar
Brush up a little on the definition of bonding. It causes more greif for inspectors than you may know.
There are components of the electrical system that are "bonded" at load-side equipment (i.e. sub panels), such as EGC's, metal conduit, etc. The rule is - no bonding of the neutrals to the panel.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/25/09, 10:30 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
I challenge you
http://www.nachi.org/electrical-pane...-challenge.htm
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Old 6/26/09, 10:05 AM
Patrick Bolliger's Avatar
Mike
The panel has one MAJOR defect.. NO legend!! I am surprised no one pointed that out.. No professional would leave that puppy unlabeled for branch circuit layout .
As for the "main" in this "distribution panel" your going to see the various configurations /types all over the place in Chicago. This is not uncommon but personally I would prefer to see one (main). Call it out... but be prepare to get ripped into. I have seen many and even had Union contractors slam me for it. It follows two different paths of concern. One occupant safety, the other electrical equipment protection. Guess which one this falls under? Your looking at client safety.. "them guys who installed it say you da wrong pal".. AFCI ain't required... We don't installed thems....
As for the closet down the hall. Very common also. Does the building have an engineer on site. Then they are the person responsible for access. Is the building a mega high rise or a three unit condo. Different configuration?
At the next chapter meeting I will have a challenge for you on Chicago electrical installations..
Old 6/26/09, 10:16 AM
Michael Larson's Avatar
The "legend" is above the preprinted label on the panel door.
Never underestimate the difficulty of changing false beliefs by facts.[/I] - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Old 6/26/09, 10:23 AM
OOPS
Focus paralysis!!
Old 6/26/09, 10:28 AM
Patrick, I know you would have seen if if you had been there.
Inspecting from pictures sucks.
Michael Larson
Hudson, WI
Main disconnect at meter instead of main panel. OK? kshepard Electrical Inspections 14 11/8/06 6:24 PM
Tenant access to main disconnect in apartment bldg? lhoffman Electrical Inspections 4 9/1/06 11:54 AM
Disconnect and Main panel srowe Electrical Inspections 10 6/13/06 7:49 PM
Main Disconnect Manufactured Home dbreen Electrical Inspections 1 3/4/06 12:42 PM
