Old 11/6/08, 3:04 PM
kpierce's Avatar
kpierce kpierce is offline
Please Note: kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default No need for the sump!
Ok here's an inspection related thread. I did an inspection yesterday on a home that was built in 2001. For the most part, the inspection went smooth. When I got to the crawl I saw a sump installed that wasn't plugged in so needless to say there was a lot of water. I followed the flow to try and understand where all the water was coming from since the perimeter grade looked fine.
Well, the corner of the foundation was very wet and I could see the path all the way to the sump bucket. I got out of the crawl to take a look directly above the the wet foundation to find the P.R.V. valve slowly leaking! Whoever installed the sump must have thought there was a grading problem or something and installed it without even looking at the source! LOL.
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 11:23 PM
Is it safe to quickly test a dry sump pump? rervanowitz Plumbing Inspections 16 2/11/09 5:38 PM
Sump pump nbhi Interior Inspections 17 2/18/08 8:07 AM
Water powered sump pump rcooke Plumbing Inspections 7 1/6/07 9:32 PM
