I usually try to write an article, every month or so, for my web site. I have just completed one dealing with a local problem, water intrusion into newer masonry buildings.
Please take a look and post any corrections or suggestions. http://deckerhomeservices.com/water%...nsultation.htm Thanks, in advance. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America) |
Will,
Many builder's don't know this or were misinformed by their suppliers and told that the block believe is should be builders' not builder's and We have a great deal of experience evaluating these type of problems believe is should be types not type Hope this helps. Mike Chris, Santa Clara, Utah
NACHI: #05051385 HouseNspect@gmail.com www.housenspect.com activerain "A man's home is his castle . . . until the queen arrives." |
Thanks. Corrected. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
http://www.wikihow.com/Use-Apostrophes InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Larry is right, there is no apostrophe called for since it doesn't show possession.
In the sentence...........when water that has been absorbed - you should eliminate the word that, so the phrase goes better with the word "and" later. This makes the sentence less clumsy (read it aloud and you'll see what I mean.) further down, when you say the regions expert, you are showing possession; ie, it is the expert of the region, so it should read region's expert. |
"Our company has become this regions expert on water intrusion problems, unfortunately, because these problems are becoming more common."
Our company has become this regions expert on water intrusion problems because these problems are becoming , unfortunately, more common. |
