Marketing geared towards realtors will soon be available for your next trade show. These colorful rack-cards promote your business through the following topics:
-Three Deadly Mistakes Every Home Buyer Should Avoid -Inspector Selection: A Real Estate Agent's Duty -Home Inspections: How Agents Can Limit Their Liability -Ten Tips to Speed Up Your Home Inspection -Move-In Certified Seller Inspections Stay tuned for more information, printed cards will be available in approximately 3 weeks. Each card is currently available for viewing in the InterNACHI Marketing Library http://www.nachi.org/marketing-library.htm Jessica Langer Marketing Director - Internachi Jessica@internachi.org |
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You might want to check with Jim Bushart, he has some good tips on marketing realtors.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
BTW - when will these be available? I teach a class to realtors called "Understanding Inspections and Limiting Liability" and could use these as handouts. Also, this class is authorized by DORA in Colorado for me to give 2 CE hours for it (under the Mountain Metro Chapter of iNACHI).
Most agents already know that stuff. I have come across some who are offended when inspectors tell agents how to do something.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
If an agent knows as much or more than the inspector then there is a problem, IMHO.. Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
they are all easily offended where I come from.....
John R Fordyce Safe-Buy Home Inspection Keystone Inspection & Testing Services NACHI #06051992 Safe-Buy Home Inspection Keystone Inspection & Testing Services << Home Inspector Marketing Map - Marketing Madness for Home Inspectors >> |
