Old 10/4/10, 8:52 PM
William J. Decker's Avatar
Default With regards to split faced
And with any masonry building construction, in Chicago.
A nice little phrasing in the Chicago code:
"All masonry residential buildings shall be inspected during and after construction by the Architect or Engineer who designed them, or by a similarly qualified representative, to verify that the building was built as designed."
So, if there is a problem with a split faced, or any masonry building, it is the responsibilty or the Architect or Engineer to make sure it is done right.
NOT the code inspector, NOT the home inspector and NOT the mason.
Helps with regards to liability and the buyer / owner can get the records to see if these guys actually did the inspection.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/4/10, 8:56 PM
Bob Elliott's Avatar
Default Re: With regards to split faced
Well it sure helps the Developer.
No more blaming them by the Judge as it is the architects job to be the site Inspector.
Looks like you just lost your phase construction work.
Old 10/5/10, 1:28 PM
Well, we still have plenty of work to do. Saw this, this morning. 20 year old single family, brick veneer at front and rear with split faced sides.
The ceiling of the top floor was a mess. Trusses rotted, and thermal imaging showing (and backed up by moisture meter readings) truss ends very wet, as well as the furing strips.
TYhey will have to get a structural engineer to design a fix and replace the roof, decking and trusses. Expensive. The new owner has been in the place for 3 months.
Like I said, look for structural, pancake collapses, this winter.
regards-split-faced-1090-howe1.jpg   regards-split-faced-1909-howe2.jpg   regards-split-faced-1909-howe3.jpg   regards-split-faced-1909-howe4.jpg
Will Decker, CMI
Old 10/5/10, 2:36 PM
George E. Russell George E. Russell is offline
Looks like the leak was in place for the full 20 years....bad stuff there!
George Russell
George Russell Professional Inspections
Austin,Texas
TREC # 10215
512-296-9538
http://georgerussellprofessionalinspections.com/
http://www.facebook.com/austinhomeinspections
Old 10/5/10, 2:48 PM
Not a leak, the roof was fine.
Combination of water going through the single wythe split faced block and, in the winter, humidity going up through the can lights into this area.
Will Decker, CMI
Old 10/5/10, 3:02 PM
Incredible. We do not make enough money. Good stuff.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 10/5/10, 8:41 PM
Looks like you had to cut your way in to the attic space.
Was it vented at all?
Old 10/5/10, 10:30 PM
Vented, out the side wall. Prevois owner, obviously because there was a history of water problems, had one vent removed (as shown by a miscolorer block.
It is very sad for the owner. Both the Architect and builder went out of business.
Go figure.
Will Decker, CMI
Old 11/8/10, 9:04 PM
As an update:
The owner called me out there, today. The contractor that the owner hired to fix it was doing the demo and replacing the trusses.
Pictures are here:
1) The old trusses, grouted into the wall pockets. No flashing and one NEVER grouts wood into masonry, especially in a single wythe wall. The fix calls for a steel ledger to support the new trusses. Bolts are through the wall.
2) The roof deck, at the front of the building (not demo'd yet) with a metal frame deck structure resting directly on the roof membrane.
3) The intersection of the brick veneer front of the house to the split block side. Please note that the air gap between the CMU and brick was grouted shut and the CMU interior spaces were not grouted, but just filled with rubble. Has anyone ever actually trained these masons?
regards-split-faced-pb080005.jpg   regards-split-faced-pb080003.jpg   regards-split-faced-pb080001.jpg
Will Decker, CMI
More on Split faced block wdecker Exterior Inspections 12 11/8/10 9:24 PM
Split faced block building problems in Chicago wdecker Miscellaneous Discussion for Inspectors 0 6/25/10 11:48 AM
Split faced block tips wdecker Exterior Inspections 0 5/21/09 6:34 PM
Split bolts cbuell Electrical Inspections 11 2/26/07 11:16 PM
