Wanted to get all of your opinions on this.
In this area (Chicago) there are many condos and townhouses that have roof decks installed. By roof deck, I mean a wooden frame (usually, 2 x 4 or 2 x 6 "joists" with deck planking on top, resting right on the roof covering (usually modified bituman), some times with some extra MB under the joists (as a cushion). This has gotten more and more popular, especially in the area around Wrigley Field (Cubs fans, go figure My beef with these is that the deck will move (temp, humidity, people walking) and the deck will rub against the roof covering and cause tearing. My experience has been that, on a new construction, the roof will start leaking in 3 - 4 years. It also greatly increases the cost of patching or replacing the roof because you have the added expense of removing the deck. Local codes to not address this, as of yet. Builder's respond to me that because it is not, specifically, prohibited by the codes, that it is OK. Sure, there could be structural concerns (especially when someone puts a huge, dirt filled planter on the deck), but my question is more aimed at the life of the roof. As for me, I call them out in my reports. "Roof deck resting directly on the roof covering will greatly accelerate the deterioration of the roof covering." Also, many good, professional roofers that I know will not work on these roofs, either patching or replacing, because they have seen early leaks and reoccuring leaks and don't want to be blamed. You know, you touch it and you are, forevermore, responsible for it. What say you? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Find an InterNACHI certified Virginia Home Inspector (and anywhere else in North America) |
I have remarked about it when the owner was present to hear me...and after his remarks, I just let it fly! (It's absolutely great to be old and curmudgeonly) "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
If you make a note in your report about the deck and roof covering that is all you can do. Make sure you note it and don't estimate life exp. to owner/buyer
Scotty |
We have thousands of them here in Philly too. I have a couple of documents about decks that might interest you. I will have to dig them up and send them to you. I think some of them are from Chicago as a matter of fact.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
