Anybody offer just roof inspections?
Lot of money in them this time of year in Arizona anyway, we get some rain now and then in the summer....I have had quite a few calls for just roof inspections lately. Good thing about doing them is the fact their easy, you can charge about the same as an entire home inspection and there is always something wrong with a roof here, I don't know about other parts of the country, but the sun destroys everything here. People don't do any preventative maintenance, when it rains the phone rings like crazy. Take a bunch of pictures of the defects and tell them to call three licensed companies for estimates..simple. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Dale, are you just referring to commercial? What do you do if the client has a very tall two story that you can't get on to the roof? I inspected a two story last month with only access in the attic to an air handler (couldn't get to any other section)and the outside was so tall I couldn't view it with my 24' ladder.
I always write these up to have them evaluated by a roofer but I don't know what I would say if it was just a roof inspection. |
Rent a manlift and add it to the cost of the inspection.
A manlift will work on a commercial inspection but not a residential. Most of the tall two story houses here are too close together to get a manlift in to.
Residential & Commercial...I just got an entire Condo complex....40 buildings, two story flat roofs, four units in each building, but one roof naturally on each building. BIG BUCKS for this simple inspection. If the roof is so high I need my 30 ft. ladder I charge more, because I need someone to hold it and help me set it up...I'm old, tired, and weak--: Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I went to the Condo's I have the contract to inspect the 40 roofs...I also found some other tid-bits of information they might be concerned about while I inspected one roof on my way back from this mornings two REO inspections.
Here is the roof of one building, pretty good shape. ![]() ![]() Now at the front portion I found Cement Tiles not attached, so I pulled a couple off to see the underlayment...oh oh...just 15lb. torn Felt Paper, they forgot the 30lb. They will be happy this was discovered, the torn felt is allowing rain to run down the OSB (when it does rain here--: ![]() ![]() ![]() Now at the back of these Condo's, they have the Heat Pump condensation drains sticking through a scupper and landing on one of the patio roofs below then ponding on the roof, which will destroy the covering (torch-down) shortly....they should be happy about this tid-bit of information also--: And I also found by accident because my contract states roof only...BUT, when I looked down at the wood trim above one window I noticed a large gap rain has been getting in the wall...so I knocked on the door and some lady answered, I explained what I was doing and wanted to know if I could look at her front window from inside, she allowed me..I did not see any moisture stains but I think I will run it by the board of directors of the Homeowners Association to IR Scan every window with wood trim above it to see if water has been coming into the Condo's... The only window in every building with wood trim at the header is in the front, all the other windows in every building have stucco, except the one....very weird design....but anyway..I think for another $9,779.00 I will ask to scan every window from the interior where there is wood trim warping allowing rain to come in...I'm sure they will go for it, and I will get a free Cam out of the deal---: Here is the Warped Wood Trim above the one window in every building. ![]() And the Condensation Drain Lines terminating through a scupper and dropping onto a rear patio roof. ![]() ![]() I think when I show them this one report for "Building #1"; this $12,379.00 ($309.00 per roof) inspection will turn into a $22,558.00 Job----!!!! Gotta love roof inspections "Only" with one window per building Infrared Scanned from the interior (if they go for it, and I bet they will)-----!!! This builder will not like me....this Condo Communities two year builder warranty----oh oh...***** will be hitting the fan AGAIN---- Another builder threatening to sue me---- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dale,
What IR camera did you purchase? |
No time for all the schooling, etc, etc. The guys I know who have them charge so little, it is easier calling one of them and doubling the price for the service, making money without doing anything.....that's much better. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Sweeeeeet Dale.
Have camera, Will travel Seriously it's a little more then point and shoot especially when tracking latent moisture in your climate. hth ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Yeah, Joe. The statement is scary, but the action is ignorant or naive.
Provide a service? Then charge appropriately. Using a $10,000 tool for free is NOT good business sense. Those of you who include it in your inspection AND charge appropriately for it are NOT included in the above. Who can give us an idea of how much you'd charge for JUST a scan of the house?? Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
Dale,
Good post and terrific pictures! Quote: Here is the Warped Wood Trim above the one window in every building. End Quote: The warped wood above the windows appears to be "interior grade" wood that would be highly absorbent to rainwater. Plus.... I do not see any type of "Vapor Barrier" or flashing. Also I do not see how it was nailed / fastened to the exterior wall. Looks to me like you might have a "Gold Mine" on your hands! If you go into the attics look for the lack of "Fire wall" separations between the units. PS: On the last two pics the "seams" look worn and like they are ready to "fail / split". Also.... the "Drain Water" is ponding.... I would recommend building up that small section so that the water drains off of the roof. Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 Last edited by fcarrio; 8/14/08 at 11:54 AM.. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 7:43 PM |
| IR In The Market Place | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 4 | 12/18/07 6:43 PM |
| Buckeye Home Inspections Service Area | sboyd2 | Miscellaneous Discussion for Inspectors | 3 | 9/4/06 7:21 PM |
