gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi all,
This house had a new roof installed. My question is, do you think that this separation in the sheathing where it "meets" is OK? There is not a ridge vent (has Gable and soffit vents). Your input is appreciated! |
Hi Greg,
Personally I am rarther more concerned about the big hole in the last picture as the shingles in this area are not adequately supported. The ridge looks fine to me Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Those were roof vents that were added with new roof. I thought they were OK. Am I mistaken? |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'd be more concerned about the aghmm...Trusses? that don't meet at the peak.
Please tell me they are homemade. |
Hi Cheremie,
Didn't notice that until you ponted it out. I think they may be done when the house was re roofed? I did think it was odd they used 2x3 instead of 2x4's for the supports |
Gerry,
My fault not mentioning the roof vents.....they were added when the new roof was put on. |
Now that I see the whole truss I do see the stamp.
In terms of the sheathing not meeting, in my opinion it is not a problem. It has nothing to do with the integrity of the structure. It is a non-issue.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
Greg,
In addition, the following picture, 100_4190 (Small).JPG, I have not seen any lateral bridging/blocking or permanent bracing added in the top & bottom cords or in the web plane. The roof sheathing and ceiling finishes may provide a part of the bracing, but web plane bracing should be added at the vertical & diagonal webs. If you have already called this out, please disregard post. Aurelio Roncone, NACHI06020793 AccuSpec, Home Inspection Services Windsor ON Canada info@accuspec.ca http://www.accuspec.ca Not Just Service. Exceptional Service! Last edited by aroncone; 3/3/07 at 1:12 PM.. |
I have installed this style truss before but only on garages with no intention of installing ceilings. They are cheaper that house trusses.
Sheathing not a problem at all. When a ridge vent is installed you'll see sheathing cut back up to three inches, so a half-inch gap is fine. Trusses are fine too.
Sometimes truss companies will do strange-looking things, but as long as you see pressure-rolled gangnails and nothing has been field-altered, it should be fine. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
There is no evidence of lateral bracing on the web members nor is there evidence of temporary lateral members that are usually left in place after erection of the trusses. Another thing that caught my eye in the pictures was that not having seen trusses before with a square cut at the ridge, the crimp pressure plates appear to have been nailed or screwed. Anyone seen this before? Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Sorry Kenton; ha. ha.
This might help understand. www.woodscience.vt.edu/researchpapers/bracing.pdf http://www.gov.mb.ca/labour/safety/roofguide.html pahi.org/.../sitebuilderfiles/roof-truss-erection-guidelines.pdf http://www.trussec.com/handling.html Up here, I was brought up to have lateral bracing whether they were stick built or later roof trusses. Not so many on homes, but most Commercial Roof Trusses come with tags on the truss chords that require permanent lateral bracing. This is one item that the AHJ will look for upon CO request. If a structural Engineer is involved, that is the first thing he will look for. For the little home, I guess they just blow in the wind and fall apart. ha. ha. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Use of ThermoPly without underlying structural sheathing? | koconnor | Structural Inspections | 12 | 10/16/07 7:52 PM |
| 10 Degree separation | pmagrone | Inspecting HVAC Systems | 9 | 8/28/07 3:36 PM |
| Exterior sheathing | adooley | Exterior Inspections | 8 | 2/16/07 9:42 PM |
| Wiring/Plumbing through separation wall | Tab M. Wilcox | Interior Inspections | 7 | 9/10/06 11:03 AM |
| Missing sheathing | jfunderburk | Exterior Inspections | 2 | 2/15/06 3:55 PM |
