----- Original Message ----- |
Per the 2003 International Residential Code section R319.1: an approved, pressure treated lumber must be used -#2 All wood framing members that rest on concrete or masonry exterior foundation walls and are less than 8 inches from the exposed ground. Best Regards Russell Cloyd Intra-Spec Home Inspections & Code Consulting, LLC Last edited by rcloyd; 1/5/06 at 9:20 PM.. |
Hi Nick,
Done Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Does this meen that on a house that has a walkout basement with 2½ sides of the house that are 2 story (ranch house + basement) block or pored basement walls, would only need treated lumber on the 1½ or 2 sides that have earth against them? Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
The IRC Code will need to be changed along with the Ban of CCA treated lumber.
http://www.bancca.org/ |
| The Inspector As Consumer Advocate | jmckenna1 | Miscellaneous Discussion for Inspectors | 1 | 2/7/07 5:12 PM |
| Recall Notice - CPSC Notice | pabernathy | Electrical Inspections | 1 | 1/25/07 8:34 PM |
| Consumer Confidence | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 11/20/06 2:38 AM |
| InspectorLocator.com getting more consumer hits. Make sure you add your services in. | gromicko | Miscellaneous Discussion for Inspectors | 3 | 4/7/06 7:26 PM |
| California consumer needs inspector's help. | gromicko | Miscellaneous Discussion for Inspectors | 4 | 1/12/06 1:24 AM |
