Is there a conflict in the following - in relation to the InterNACHI Res. SOP:
2.4. Heating II. The inspector is not required to: B. inspect fuel tanks or underground or concealed fuel supply systems. 2.6. Plumbing I. The inspector shall: H. describe any visible fuel storage systems; |
| Find an InterNACHI certified Wyoming Home Inspector (and anywhere else in North America) |
No conflict.
One is concealed and the other is visible. Do you see this as a conflict? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
2.4. Heating
II. The inspector is not required to: B. inspect fuel tanksThat fuel tank in that statement is not buried. The placement of the words "underground" and "concealed" are important. |
Still no conflict IMHO.
I can describe a 100lb. Propane tank as being the fuel source but I am not required to inspect it. I don't inspect gasoline and diesel tanks on a farm either. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
ditto
I see the distinction between "identifying" a component, "describing" the component" and "inspecting" its condition.
Personally, as an inspector, I did not limit myself to doing just one. For every component and system, I often found myself doing all three simultaneously. I saw no value to my client in doing just one without the two. ![]() For example (using above pictures of a fuel tank): According to the SOP, I am required to identify and describe the fuel tank, but I'm not required to inspect it. Correct? |
According to the SOP, I agree that is what it appears to say. I see the dilemma that Ben is pointing out though. How do you describe it, if you aren't somehow inspecting it?
By simple noting the fuel type and storage tank location.
You have to look at (or in your clients eyes, "inspect") it to note it.
But if I had to report to you....and be accountable for how I reported to you....his effectiveness as a home inspector (his "condition", if you will), that is a difference that I do not want to accept responsibility for. Fuel leaks can create environmental conditions of epic proportions. I don't want to be connected with that and my SOP provides me the distance. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
By describing it, in the clients eyes, you have inspected it. If you do not note any defects for it, you are taking ownership of it (regardless of what the SOP states.) I think Ben's observation that there is (at least an implied) contradiction is correct. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I don't....especially when the SOP disclaims it. Ben's "inference" can be applied to anything in the house, since you are "inspecting" it. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
That's a good point, however I'm not "noting" everything in the house. I'm only noting the things I am inspecting. If I note something, the inference is that I am also inspecting it (unless I specifically disclaim it in the report.)
Or if it is disclaimed in your SOP.
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
