Old 6/10/08, 1:15 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default SureTest vs. GFCI tester
I'm looking to hire someone who knows how to use a SureTest device.
My goal is to wire up at least a dozen receptacles, each with a different electrical defect, each giving a different test result using the SureTest device.
And then compare those results from the SureTest device with a simple GFCI tester.
Anyone capable and interested in being hired to come to NACHI.TV and build this demonstration with us?
Old 6/10/08, 1:51 PM
Jeffrey R. Pope's Avatar
Default Re: SureTest vs. GFCI tester
Are you paying for travel expences? I hear the slopes are open again. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/10/08, 2:33 PM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Default Re: Sure Test vs. GFCI tester
I am not sure but I don't think there are 12 ways to mis wire a receptacle.
Also I don't think a sure test has that many functions.
Frank Magdefrau
Certified Master Inspector
DeSoto Home Inspection Services
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Old 6/10/08, 3:42 PM
"There must be 50 ways to leave your outlet...
I heard that there was an ASHI convention, in which an electrician had many receptacles lined up. All wired improperly. All differing from each other. And he had inspectors inspect them one by one. Most inspectors used a simple GFCI tester. The cool thing about was that all of the receptacles had electrical wiring defects, but the testers that the inspectors used did not have the ability to detect them. Which just gave everyone a scare.
Old 6/11/08, 2:37 AM
As to how many ways one can screw it up, the answer is neither 50 nor 12. There are exactly 125 possible ways to wire a 120 volt receptacle. This is derived from the fact that there are 3 terminals on the receptacle, and there are 5 ways to wire each terminal (Line 1, Line 2, Neutral, Ground, No Wire Connected)
Old 6/11/08, 3:53 AM
tdietrich1's Avatar
Originally Posted by bgromicko
I heard that there was an ASHI convention ....... testers that the inspectors used did not have the ability to detect them.
Sounds like operator error.
Old 6/11/08, 11:51 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
I agree with the last statement.
Old 6/11/08, 6:47 PM
I think that's the point. Isn't it?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/11/08, 9:16 PM
Jeff Merritt Jeff Merritt is offline
Contact John Dukes at Ideal Industries. he has a great layout of what the sure test can do, drop me a line for his contact info. We had him as a guest speaker. at a chapter meeting. I would think that Ideal would have a rep in the area and would be more than happy to do iNACHI TV.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
Help GFCI Tester Showing All Lights kmccullough Electrical Inspections 8 4/19/08 2:11 PM
GFCI won't trip by tester rstufflebeem Electrical Inspections 22 3/22/08 9:10 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 9:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 1:29 PM
