Looking for some ideas on what to use to trim this tile with, I know I can use some type of a wood trim but thought someone might know of some thing that might dress it up better.
Thanks, ![]() ![]() David
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Hard to tell looking at it. I assume just grouting is not an option due to the corners.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
A thin gold would add class ,but that grout looks discolored to me.Is it sealed?
rip it out and start again.
Unless you use a decorative matching bullnose tile on these corners, there is not much choice other than this;
http://www.shagtools.com/tools/Schlu...9-RONDEC-P.cfm LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Yes Bob it was sealed, maybe what you are seeing is from the camera shot
Several ways you could have done prior to where your at now, bull nose as mentioned, using a pre-set trim. I personally just like to cut the edges on 45's or what ever you need and looks like a normal grout line. If you don't want to start over and want to try anything, I had a friend use auto edge molding which is not as wide as the wood trim and didn't turn out to bad. Funny as hell but was surprised on the look. Of course nothing looks as good as the right way.
Fort Worth Home Inspector Dallas Home Inspector |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
wnapier is a non-member guest and is in no way affiliated with InterNACHI or its members.
Black RTV, epoxy or maybe some angle hair then paint to match?
Al in TN |
| Water under marble tile | rhensel | Interior Inspections | 20 | 1/15/10 5:50 PM |
| Tile wall...needs a drainage system? | jfunderburk | Exterior Inspections | 5 | 12/11/09 4:38 PM |
| Garage Roof Tile | gheller | Exterior Inspections | 4 | 6/18/08 9:23 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
| how to properly walk on a red tile roof ? | jimhanson | Exterior Inspections | 14 | 1/26/06 12:00 AM |
