I'm an inspector from Manitoba, Canada and I'm getting a fair number of basements that are properly studded, insulated, polied and drywalled. But the common thing to do is to remove the drywall, poly and insulation in specific sections of basements to make room for a cold storage area. They then insulate interior walls to contain the cooler temperatures. I'm finding that these areas usually contain mold growth. Is there a better way to build a basement cold storage than to remove these necessary components?
Curtis Hildebrand Kingdom Home Inspections |
| Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America) |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
It appears improper air circulation in these storage cellars are the cause of the mold, I have found in my area.
Add a de-humidifier. Basements, being underground, are natually moist.
Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| something else to chew on | john bubber | Structural Inspections | 706 | 4/25/12 7:13 AM |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| gutter downspout to basement drainage system | David Paterson | Exterior Inspections | 2 | 12/18/06 6:27 PM |
