Old 2/2/08, 11:06 PM
rkeith rkeith is offline
Default Vent Question
Gas furnice in upstairs encolsed area-fresh air vents go from enclosed area into attic area. Is this OK or should it vent to outside?
Thanks, I need this info ASAP
Old 2/2/08, 11:14 PM
James Budrow's Avatar
James Budrow James Budrow is offline
Default Re: Vent Question
Yes thats ok.
James Budrow
American Pride Home Inspection Service
5714 Folsom Blvd Suite 106
Sacramento CA 95819
1-877-IB4-UBuy(877-424-8289)
http://www.InspectSacto.com
http://www.APInspectionService.com
http://www.SacramentoInspection.com
President-Sacramento Valley Chapter (InterNACHI)
Old 2/3/08, 5:36 AM
Robert Sole's Avatar
Robert Sole Robert Sole is offline
It's OK as long as the attic has proper ventilation. It would have to be changed if the attic were insulated and the vents sealed as they are starting to do in some homes now.
Robert Sole, CMI
407-637-7288
Florida license numbers HI 169 and MRSA 92
Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties.
RobertSole@REMinspections.com
Check out my blog orlandohomeinspections.info/
REMinspections.com
OrlandoHomeInspector.net
Old 2/3/08, 5:57 AM
Combustion air...?
Larry Kage, CMI
231 929 3525
Old 2/3/08, 5:59 AM
Barry Adair's Avatar
What kind/size of enclosed area and how many floors between it and the attic?
This all depends on the size of installed unit, vent sizing, their location should be 2 hi/lo, what other gas appliances are in the proximety...there are supposed to be a manual/instructions present for all gas fired appliances...if they aren't onsite I note as a deficiency and take down as much info (model/serial) about the unit and check it out back at the office...before sending report to client
probably not ASAP as you wanted but more info will be required before answered without this and photos
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 2/3/08, 6:13 AM
Originally Posted by lkage
Combustion air...?
The furnace we recently installed in my house enclosed area needed 1 sq. inch of combustion air (split high and low) per 4000 btu input of all gas appliances in that enclosed area if run in vertically. And double that if run in horizontally. We came direct from outside.
Edited:
I checked for my Rheem and the exact wording is:
"Each opening shall communicate directly, or by ducts, to the outdoors or spaces (crawl or attic) that communicate with the outdoors."
Larry Kage, CMI
231 929 3525
Old 2/3/08, 6:19 AM
David P. Valley's Avatar
As stated already, the attic is fine for combustion air as long as it's vented properly. Gable end vents are not considered adequate with todays tighter homes.
A properly vented attic is basically....outside.
Old 2/3/08, 11:26 AM
THANKS EVERYONE! It is worth the membership dues to have access to this knowledge base.
Rusty
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 9:17 AM
Has anyone seen this type of vent material? scosta Inspecting HVAC Systems 12 3/9/07 2:30 PM
Bathroon vent bemelander Inspecting HVAC Systems 8 2/3/06 2:40 AM
