Old 10/30/07, 2:01 PM
Chris Morrell's Avatar
Chris Morrell Chris Morrell is offline
Director of IT
Send a message via ICQ to inxil Send a message via AIM to inxil Send a message via MSN to inxil Send a message via Yahoo to inxil
Question Weather-Proofing + Cats
Hey guys,
This is a complete non-NACHI question. I live in an old, 18th centrury brick row house in Philly that hasn't seen a ton of work done to it. Needless to say, it's pretty drafty, so I'm starting my weather-proofing process for the winter. We've traditionally used that stick-on window film to block the window drafts, but since we adopted two cats, the film hasn't lasted a day, let alone a winter. I'm trying to think of some sort of creative way to seal those windows without turning to thick shades that will block all the light (the cats don't seem to mind curtains/blinds). Have any of you come across any good solutions to this problem, either out on an inspection or in your own home? I'm thinking about doing something with plexiglass, but I'm curious about other solutions...
Thanks!
Old 10/30/07, 3:24 PM
jschulte jschulte is offline
Please Note: jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Weather-Proofing + Cats
There is a temporary caulk material made for weather-proofing. It stays in place for the winter and you peel it away in the spring. I don't know if the cats would mess with it though.
It does not work as well as the plastic but cuts down on drafts.
Personally I would recommend using the plastic and disposing of the cats (only in a safe, humane manner, however).
Old 10/30/07, 3:57 PM
gbeaumont's Avatar
Hi Chris,
I would go with the plexiglass after doing as much as you can with caulking to reduce drafts, I would also use caulking with the plexiglass.
Or move to Florida for the winter
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 10/30/07, 4:18 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Get a dog instead of a cat.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 10/30/07, 5:15 PM
ldapkus ldapkus is offline
Get a dog to chase the cat away from the windows.
Old 10/30/07, 6:14 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Give me a call if you want someone to come over and take a look and make a few suggestions. I live fairly close to you. We could just work out some kind of deal for the time it would take.
Old 10/30/07, 9:39 PM
Director of IT
Thanks for the offer, Scott. I don't think it's that big of a deal--I was just looking for suggestions. I think I'll end up using a combination of plexiglass and that temporary caulk. Unless someone else has a better suggestion, that is.
Cheers,
Old 10/30/07, 9:42 PM
Michael Larson's Avatar
There is aproduct that can be applied on the outside but that is probably not an option for your place.
Old 10/30/07, 10:07 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is offline
I have a golden retriever, the cat stays in the garage.
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Old 10/30/07, 10:27 PM
Charley L. Bottger's Avatar
Charley Rule # 1 and 2 Humans live inside animals live outside </IMG></IMG>
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/30/07, 10:29 PM
Richard L. Bennett Richard L. Bennett is offline
Stop the cold air
Next insulate
Plexaglass is not cheap
Turn the furnsace down and dress warm
63 is a good temp
rlb
Old 10/30/07, 11:01 PM
Doug Edwards's Avatar
http://www.diynetwork.com/diy/hm_oth...241095,00.html
Old 10/30/07, 11:43 PM
Patrick Bolliger's Avatar
Chris,
I don't know if you can find it but metal mesh (insect) screen over the plastic sheets should deter kitty and still allow you to get light and see outside.
Keep in mind any Plexiglas covering maybe a fire hazard if you need to escape from that windown in a hurry...
or Else get a DOG....
Old 10/31/07, 6:20 PM
James J. Rooff James J. Rooff is offline
Oh just duct tape their little feet.
House Wrap brepanshek Exterior Inspections 26 10/4/08 9:45 PM
Vinyl siding installation guide badair Exterior Inspections 18 3/27/07 5:38 PM
Live weather cover jnicholson Electrical Inspections 13 10/31/06 10:31 PM
Weather head dmacy Electrical Inspections 3 2/8/06 7:19 AM
