Go Back   InterNACHI Inspection Forum > General Inspection Topics > Legislation, Licensing & Legal Issues for Inspectors
Legislation, Licensing & Legal Issues for Inspectors Use this forum to discuss current and proposed legislation on home inspector licensing, and other legal issues affecting home inspectors. Inspectors from all associations welcome.
Old 2/12/06, 10:30 AM
Default Massachusetts Home Inspector, Changes in SOP
Attention:
Next Meeting will be held on March 8, 2006 at 8 AM at: 239 Causeway Street, Boston, Massachusetts
To discuss proposed changes to the Massachusetts Home Inspector SOP in CMR 266.
http://www.mass.gov/reg/boards.htm
1. Home Inspectors should advise of the defect(s) and that they should be repaired.
Stop referring to the electrician, or other expert, gives credence to the HI as a Professional soon to be permitted to use a State Seal also proposed.
2. According to the Massachusetts State Board of Electrical Examiners it will be proposed to make it illegal for a Home Inspector to remove any panel cover, because that work must be done only by licensed electricians.
3. Wearing PPE during inspections
4. Editorial changes to correct language and add specific recognized terms used in the electrical industry.
5. Make it clear that repairs should be made in accordance with any codes or standards recognized by the State of Massachusetts.
5. Suggested use of NFPA 73 Electrical Inspection Code for Existing Dwellings
See the attachment for NFPA 73 as a PDF file below
http://www.nfpa.org/aboutthecodes/Ab....asp?DocNum=73
Document Scope: 1.1 Purpose. The purpose of this code is to provide requirements for evaluating installed electrical systems within and associated with existing dwellings to identify safety, fire, and shock hazards, such as improper installations, overheating, physical deterioration, abuse, and similar conditions. This code provides criteria that enable the identification of the hazardous conditions that are evident during a visual inspection of an existing dwelling. This code does not define installation requirements that might be desired for convenience or utilitarian purposes.
Current Edition: 2006 Next Revision Cycle: Annual 2010
PS: I will be there!
Old 2/12/06, 10:51 AM
gbeaumont's Avatar
Default Re: Massachusetts Home Inspector, Changes in SOP
Hi to all,
Joe, where does it state that only licensed electricians are allowed to remove panel fronts?
I believe the actual verbage says "qualified pesons" and the deffinition of a qualified person is someone who has been trained or instructed as to the safety issues surrounding the inspection of electrical installations.
Am I wrong, is there something different under Massachusetts law?
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 2/12/06, 11:12 AM
Bruce A. King's Avatar
Gerry,
I think it is only a proposal to make this change. I also think that it will harm the home buyers since it will result in many uninspected panels. The reason is that many people will not ever get the electrician out there to inspect it.
Many places such as here still need the work done by electricians inspected by home inspectors. Typically about 50 to 75 percent of the writeups are actually fixed and many times one or two new problems are inserted during the process.
www.BAKingHomeInspections.com
704 301-3207
Old 2/12/06, 11:51 AM
gbeaumont's Avatar
Hi to all,
Bruce, I know you are correct. typically we report electrical defects in a very high % of inspected properties, and if we are limited from doing so that will be to the detriment of our clients, we commonly find issues that require repairing that affect the safety of people within the home.
I think the electrical industries attempt to stop Home Inspectors from evaluating panels is merely an attempt to control what they percieve as solely their business.
I actually think NFPA 73 is a good document, but so is NFPA 70 which defines a "qualified person" my job as an educator is to ensure thaat home inspectors are qualified persons, so they are able to do their job well and in a safe manner.
I am very interested to hear Joe Tedesco's opinion of this.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 2/12/06, 12:35 PM
Originally Posted by gbeaumont
Hi to all,
Regards
Gerry
Gerry I met the MA Bd of Elec Sec'y when I was having my coffee at the 2/8/06 ,meeting, and mentioned that I was requesting support for HI PPE because I wanted HI safety to be considered. He said that he would address the board in March indicating his concern related too the removal of panel covers by HI's.I support the "qualified person" definition. I believe he is interested in bringing the Board up to speed with changes in the industry related to dwellings and arc flash accidents. I sent Nick a panel with over 50 Defects to be used to Qualify our people.
Old 2/12/06, 12:47 PM
Paul W. Abernathy's Avatar
Joe,
I understand you will be there when this takes place, Understanding your dislike for HI's to go into the panels in the first place I would be interested in knowing your position on this.
I do not recall an increase of HI's deaths due to inspection of Electrical Panels, in fact I think it increases the safety aspect of the home owner and makes MY job as an Electrician less task oriented and more direct in solving problems.
I only see this panel proposing these issues with the guidence of someone, I am not saying it is you but someone with a negative view or slant on the HI industry is obviously peeping into the correct peoples ear on issues.
OK....First the HI side of me will come out.......Ok.....From a HI standpoint I am trained to look at the obvious ( speaking as an HI only now..not ELE )...Most all HI's have some sort of formal training and if not they will not last long.....anyway the majority of observations in an electrical panel are simple and straight forward and when it is obvious the Electrician is bought in....clean and simple solution...two eyes are better than one set of them in my opinion.
OK...my Electrical Hat will now go on.....I do not agree with the idea of making it only offered to electricians to do this very BASIC of observation..it is MY opinion that HI's for the most part do a fine job in finding the basics of anything electrical that are within a service enclosure.....they are not fixing it, they are not removing anything regarding it....Also if the effort is to save HI lives....I do not believe I recall any HI's who have died from removing a service panel cover......but again maybe you have more faxtual info on that occurance.
As an Electrician I simply do not have the time nor desire to do cheap electrical inspections so that a homeowner can pay me $ 75.00-$ 100.00 to look at something the HI could do as part of their normal inspection...if their is something obvious I will get the call anyway and THEN I can do the inspection with the idea of getting the work as well......spending my time to make $ 75.00 or $ 100.00 is not something most ACTIVE electricians want to spend time doing ......this is from experience as I am in the field everyday working and doing this trade..not simply as a inspector...but actually DOING the wiring....getting my hands dirty so to speak.
Now......I have an opinion on the motive behind the MASS Board personally...but will reserve to keep it to myself.....however, if the intent is to create a training program just for HI's is the purpose it is a WASTE of time and effort...this is already being done my some of the fine work Gerry and other Educators are doing nationwide......
Ok.....time for the GOD complex.....While I care about safety, I care about my fellow man and all that JAZZ......Electricians are no GODS....we pull the panels like anyone else...call me what you will.......but HEY i physically PASSED (3) STATEWIDE exams to get my licences....not a cracker jack box or gifts from the state.....( TRUST ME IT HAPPENS )
I have just done it so many times.......and well I also do wear glasses with plastic lenses so it affords me some slack but when asked to nearly 2 dozen of my electrical buddies, do they wear PPE when they pull a panel...well 100% of them just do not.....so that comes to the term " Qualified Persons "
As defined by the 2002 NEC- One who has skills and knowledge related to the construction and operation of the electrical equipment and installations and has received safety training on the hazzards involved.
Ok the change from previous was the addition of " Safety Training "....ok...now leaving it to a board to define WHO can and WHO DOES the safety training is where I start to have issues.....because to be honest with you most HI's get this on a daily basis just by reading this board....but I will stop right their before I inject to much of a personal feeling and flavor to it.
So......is the MASS Board going to determine WHERE a HI can get " Safety Training " to meet the Qualifed Person requirement....Hell I could put that together in a online seminar in less than 2 weeks......
Personally I think every organization NACHI, ASHI, NAHI and others can rectify any change why simply offering a class regarding electrical safety...IN fact it can be put into a CD format......but I do not see the need to have HI's PAY to achieve this......
I have to say.....as an Electrician with over 18 years experience in the trenches....I am not threatened by HI's....I think they create work for my industry, I think they keep an eye on things we electricians may not see because the happy homeowner may never invite an electrician in the house for years after it is built....
ALSO I see a conflict of interest...if you let the electrician do the inspection and they find things wrong...are they going to be allowed to FIX IT...or will it be looked at as a conflict and if NOT....why say it is when a home inspector finds something and then cant offer to fix it.....creates a whole new meaning to seperation from the issue at hand...
I think in closing the HI does a valued job..and not because I am one...I coudl give up the HI business tomorrow and I am in my heart a FULL BLOODED electrician.....that i cant change...it is in my family.....but I have no problem at all with HI's doing the basic evaluation..WHY because I know in my heart if they find something and as we can see HI's spend ALOT of time learning electrical issues...which is why I spend alot of time here answering them....dont you think I have BETTER things to do...well I do fella's but the members of NACHI need us...to give our views and points....having Me, Greg, Joe who are in the field and had BOB but not sure where he went....he is missed....we give field perspective....then those with advanced knowledge like Gerry, Jeff, Jay and others come in and add additional information...
If you do not call that creating some of the BEST " Qualifed Persons " to do an evaluation I dont know who is....in many states Electricians have no continued education as well......but good ones ALWAYS strive to learn more...I learn EVERY DAY............NO one is too smart to learn why 6ma's can kill ya....NO ONE.
Paul W. Abernathy,CMI,CPI,CME
Old 2/12/06, 12:52 PM
Ted Allen Ted Allen is offline
Nice post Paul.
Old 2/12/06, 12:57 PM
Yes he is.
Old 2/12/06, 12:59 PM
gbeaumont's Avatar
Hi to all,
great post Paul, it would be nice to think that common sense prevails in this area.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 2/12/06, 1:10 PM
Hey Guys- To be honest with you I am against government medling at all levels...I think I spelled that wrong...anyway.....I think the concept of PPE and great......and will save lives...I think people SHOULD be qualifed to open panels......BUT as stated I think HI's meet this very basic of requirement as it pertains to inspections.....
Now....not in regards to installing it.....as govered by the NEC.....just in terms of inspecting it.......after all my X-RAY eyes dont always work either when looking into walls that are finished.
I think if the MASS BOARD wants to mandate something they should simply say that upon basic obversation that a Licensed Electrical Contractor..NOT ELECTRICIAN....Electrical Contractor should be contacted......
What this says to the consumer is...if basic principles of electrical installation and safety are not followed.....it is REQUIRED that the HI call in the Electrical Contractor....again NOT Electrician and I wont go into why I feel that way on that....
Just seems to me JOE can be positive in pushing this to the MASS Board at the meeting.....ok....PPE is fine...push that and well it only costs 5-10 bucks for some eyewear and so on.....BUT simply push that HI's are qualified persons under the idea of inspections and require them to refer to licensed electrical contractors upon observation....this is what HI's want to do anyway......
I think JOE can assist in this here if JOE agrees to the concept.....What do you say JOE....?
Old 2/12/06, 1:20 PM
I always wear my glasses and some good gloves. I also always check the box, pipes etc. with my "buzz and blink" tester before touching anything that could possibly be hot.
I would like to think most folks do the same.
Old 2/12/06, 1:45 PM
David P. Valley's Avatar
Paul,
I like your attitude regarding any Electrical proposals that may come to light in the very near future in Ma. due to circumstances beyond our (meaning us HI's) control.
It would be fantastic to have someone like you to attend this upcoming MA HI board meeting.
Very nice post...
Old 2/12/06, 1:49 PM
Hmm...I am not sure I understand this reasoning.....the basis for HI's are to be generalists...not experts in any one field unless of course they are....the basic principles applie to detection but do not make someone an expert.
OK....so what is the SEAL FOR....what will the home inspector inspect if they cant refer it when they find it.....This methodology is FLAWED.....
The saving grace to most HI's are the ability to refer and use it wisely....hell a home owner with many years of experience could probably do their own home inspections...we all know this.....BUT having it done by a professional EVALUATOR who knows when to call in an EXPERT is a value needed to the end consumer....
Am I reading that quote wrong...please help me understand this way of thinking....
Old 2/12/06, 1:51 PM
If they would like me to attend...I will attend...BUT I think JOE can be a voice for the HI's if he undertands what I am saying and see's the value in it.....probably a better voice than me since they know him.
Old 2/12/06, 1:58 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I will add to this discussion that as inspectors we only "add" to the financial well being of electrical contractors with all the stuff we find wrong electrically on inspections!
