| Legislation, Licensing & Legal Issues for Inspectors Use this forum to discuss current and proposed legislation on home inspector licensing, and other legal issues affecting home inspectors. Inspectors from all associations welcome. |
Without going into detail I think I need to make everyone aware that it appears that SC does not enforce or acknowledge the SC SOP anymore but still sends it out to new inspectors.
I was told by someone in Columbia at the LLR that they can only enforce the actual laws concerning licensing. Here is all I can find in the actual law that resembles a SOP, they call it a commission approved form. I verbally requested one to see if they would just send the SOP but I have not received anything. From SC law: SECTION 40‑59‑560. Inspection reports; form; disclosure of scope and limitations. (A) An inspection report issued by a licensed home inspector under this chapter must be on a form approved by the commission. For purposes of this section, a form that contains the same information as the commission‑approved form is considered to have met the requirements of this section. (B) Nothing in this section may require a home inspector to inspect every item contained in the commission‑approved form, and nothing in this section may limit a home inspector from performing a home inspection beyond the scope of information contained in the commission‑approved form. A home inspector shall indicate on the inspection report which items, if any, were not inspected. (C) A home inspector shall disclose the scope and limitations, if any, of each inspection before performing a home inspection. Note that the only place you can find the SC SOP on the LLR website is with the new inspector application starting on page 7 at http://www.llr.state.sc.us/pol/Resid...iles/HIAPP.pdf It does not have any statute numbers on the SOP and it is called a guideline. Can some of you call and enquire about this? I can't seem to get anywhere with it and I am usually good at this sort of thing. http://www.llr.state.sc.us/pol/ResidentialBuilders/ B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| California Home Inspections | whandley | Miscellaneous Discussion for Inspectors | 17 | 6/4/08 12:28 AM |
