Go Back   InterNACHI Inspection Forum > General Inspection Topics > Legislation, Licensing, Ethics & Legal Issues for Inspectors
Legislation, Licensing, Ethics & Legal Issues for Inspectors Use this forum to discuss current and proposed legislation on home inspector licensing, and other legal issues affecting home inspectors. Inspectors from all associations welcome.
Old 5/7/13, 10:52 AM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
InterNACHI Admin
Default Why won't the home inspector enter a wet crawl space?
http://www.nachi.org/memo-realtor-crawlspace-water.htm
President, Contractors Association
Author, How to Run a Successful Home Inspection Business
Founder, InterNACHI
Owner,Nick Gromicko General Contractor
"Just as iron sharpens iron, one man sharpens another."- Proverbs 27:17
Planet InterNACHI.... resistance is futile.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/7/13, 1:13 PM
InterNACHI Admin
Default Re: Why won't the home inspector enter a wet crawl space?
Here is how to create your own clean copy of this document to keep on your inspection truck: http://www.nachi.org/myowncopy.htm
Founder, InterNACHI
Old 5/10/13, 7:46 AM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
I had a pier and beam house a few years back that I inspected which had about six inches of standing water under it. Low hanging electrical wires, etc..in the crawl space. I informed the client and the agent that I could not/ would not crawl it for safety reasons. Realtor gave me a disgusted look and said "we'll just get a guy with a wet suit!"
I wonder how that worked out for them.
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
Old 5/12/13, 4:35 PM
Shortly after I moved back to Kansas City in the late 80's a home inspector declined to enter a crawlspace / low (under 3' high) and wet (standing water over 75% of crawlspace that was 6" to 12" deep); and recommended the crawl be pumped out / dried out and reinspected AFTERWARDS.
The Realtors be-rated him intensely and got another person / handyman contractor to enter to check the wet crawlspace out.
Its my understanding the 1st home inspector got paid very well for his expert witness testimony later after the handyman was electrocuted.
Old 5/12/13, 9:26 PM
InterNACHI Admin
Wow.
Founder, InterNACHI
Old 5/13/13, 12:15 AM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Just had that a month ago.
I said no way.
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
www.homeinspectionpeoria.com
Old 5/13/13, 12:25 AM
James H. Bushart's Avatar
I knew it was going to be a problem when I removed the cover and caught a wave.
Old 5/13/13, 2:08 AM
Attachment 65276
Attachment 65277
You mean it started to drain when when you popped the cover?! That's some serious infiltration.
Cameron Anderson
Since 2004
Old 5/13/13, 8:32 AM
In the first photo ... the water is flowing from the entrance.
Old 5/13/13, 10:38 AM
It's times like those when frantic scrambling for a camera typically occurs.
Cameron Anderson
Since 2004
Old 5/17/13, 4:49 PM
skingery skingery is offline
well, at least you knew the seal and weatherstripping on the access panel was in good shape.
Old 5/18/13, 7:58 AM
lstark lstark is offline
I just did an inspection where I made the decision not to enter the crawl space. There were 4 primary reasons I stated in my report. 1) Accessibility 2) Height restrictions (ground to floor joist height between 18" and 36" 3) Excessive Debris 4) Electrical wires. Although I didn't see any standing water from the outside entrance to the crawl space, I was able to tell that the ground had a high moisture content. The Realtor also told myself and the clients at the beginning of the inspection that the owner had just replaced the sump pump which failed during a recent period of time with heavy rainfall. She also said the crawl space took on water. The home was built in 1928 and was originally designed as a seasonal lake cottage which then at some point was converted to a full time residence. Several additions (including a 2nd floor) were added to the house. From my limited view I was able to see a lot of electrical wiring that was run under the floor joists. My primary reason (and the one I communicated to the clients) was the electrical shock hazard. I felt bad that I wasn't able to inspect an important part of the house but felt the risk was too high. I also communicated to the clients that the only way anyone should enter the crawl space is with the electrical service to the house turned off to eliminate the risk of electrical shock. As we all know, inspectors are prohibited from turning off the electrical during an inspection. The clients were a little disappointed that the crawl space couldn't be inspected but seem to understand my reasons. Safety first!
Larry
Old 5/18/13, 8:27 AM
LOL. Indeed. I forgot to mention that in my report, though.
Florida Licensing Bill - Action Soon jburkeson1 Legislation, Licensing, Ethics & Legal Issues for Inspectors 250 7/1/10 4:50 PM
Buyers Best Home Inspections ddinwoodie Miscellaneous Discussion for Inspectors 6 9/4/06 7:20 PM
Home Inspector Listings Part Two jbowman Miscellaneous Discussion for Inspectors 8 8/29/06 8:52 PM
