Go Back   InterNACHI Inspection Forum > General Inspection Topics > Legislation, Licensing & Legal Issues for Inspectors
Legislation, Licensing & Legal Issues for Inspectors Use this forum to discuss current and proposed legislation on home inspector licensing, and other legal issues affecting home inspectors. Inspectors from all associations welcome.
Old 8/18/09, 9:22 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Wind Mitigation: Please proof this new inspection article.
http://www.nachi.org/wind-mitigation.htm
Find a Home Inspector
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 8/18/09, 9:59 PM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
Default Re: Wind Mitigation: Please proof this new inspection article.
Roofs can also meet the Miami-Dade building code
I don't know that I would call it a "State-certified" inspection anymore.
Possibly, a "qualified inspection."
I would point out that the garage and other opening should be covered by Impact Rated devices, including Impact rated garage doors. Most people(including inspectors) do not understand Impact rated vs. Wind rated, there is a huge difference. They do make a garage door with windows that is Impact Rated. Just my opinion, though. I hope this helps. More
wind-mitigation-please-proof-new-inspection-article-img_6881.jpg   wind-mitigation-please-proof-new-inspection-article-img_6882.jpg
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 8/18/09, 10:00 PM
Dennis J. Bonner's Avatar
Dennis J. Bonner Dennis J. Bonner is offline
article looks good-remember wall construction type..ie- wood vs. re/un enforced masonary makes a big difference on whether the underwriter insures the home as a superior construction type or not. many people overlook this but it can affect the premium substantially. as for opening protection-skylights and glass block windows are usually a deal breaker-these need to be verified. overall looks good
Old 8/18/09, 10:03 PM
Glass block is now considered a Concrete Masonry unit(FBC) and does not need to be shuttered
John Shishilla
321-327-2950
Old 8/18/09, 10:38 PM
Kenneth A. Townsend Kenneth A. Townsend is offline
Secondary Water Barrier should may be changed to "Secondary Water Resistance (SWR)".
Foam insulation is not the same as "Foam SWR Barrier"
Good article though.
Kenneth Townsend, CPI
Gulf Coast Inspections
Professional Inspections and Consulting
Bradenton, Florida
941-779-4400
Serving the beautiful West coast of Florida
"Guard Against the Impostures of Pretended Patriotism"
George Washington, 1796
Old 8/19/09, 1:10 AM
as far as the hvhz is concerned- section 1626.1a, FBC, Building Volume(2007) provides; All parts or systems of a building or structure envelope, such as, but not limited, to exterior walls, roof, outside doors, skylights, glazing and glass block shall meet impact test criteria or be protected with an external protection device that meets impact test criteria. Test procedures to determine resistance to wind-borne debris of wall cladding, outside doors, skylights, glazing, glass block, shutters and any other external protection devices shall be performed in accordance with this section.
Old 8/19/09, 8:28 AM
Wind Mitigation is not a code inspection. What the code requires and Office of Insurance regulation are two very different things. This is one of the biggest reason for problems.
John Shishilla
321-327-2950
Old 8/19/09, 9:16 AM
the mitigation requirements use the florida building code as the standard for roofing and opening requirements. The new form actually goes a step further. The msfh training manual as well as the fbc consciders glass block a glazed opening and requires protection by an approved device set forth by the fbc. If there is something new i am not aware of please refer me to the source.
Old 8/19/09, 9:24 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is online now
MSFH considers Glass Block that has been installed with mortar as a masonry unit and is considered protected, whereas the plastic units with sillycone caulk require protection
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 8/19/09, 9:31 AM
MSFH has left a link to all MSFH certified inspectors for the insurance companies to verifiy.
http://www.mysafefloridahome.com/forhomeinspectors.asp
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 8/19/09, 9:45 AM
They are called inactive inspectors and the latest expiration date on the inspector list is 6/30/2009.
Bradenton, Florida
941-779-4400
Old 8/19/09, 9:54 AM
bruce, is there anywhere i can read that about the glass block?
Old 8/19/09, 10:33 AM
MSFH changed this the last year of the program along with OSB. Glass block is also listed in the FBC under Concrete masonry unit. The best way to learn what the insurance companies are looking for is to take a class. The 1802 form is written by the Office of Insurace Regulation(OIR-B1-1802) not the consrtuction boards. Right or wrong it is their form. The changes and problems occurred because of the two differnet entities. You used to be able to build a house that meets current codes but does not meet the insurance discount requirments. They are slowly getting to gether and making it more consistent.
John Shishilla
321-327-2950
Old 8/26/09, 7:58 PM
Richard Murphy Richard Murphy is offline
The MSFH training treated glass block differently depending on whether or not it was in the HVHZ (Miami/Dade). Inside the HVHZ glass blocks are considered openings and not counted as openings outside the HVHZ
Old 8/26/09, 10:17 PM
gable vents too,huh?
Florida Wind Mitigation ktownsend Legislation, Licensing & Legal Issues for Inspectors 33 8/19/09 9:52 AM
Orlando Wind Mitigation Needed dshockley General Inspection Discussion 0 8/2/09 7:46 PM
Are electricians supposed to use these tools as per 70E? jtedesco1 Electrical Inspections 27 12/15/07 4:40 PM
