| Legislation, Licensing & Legal Issues for Inspectors Use this forum to discuss current and proposed legislation on home inspector licensing, and other legal issues affecting home inspectors. Inspectors from all associations welcome. |
Should inspectors write their report observations in the past tense?
I say, "Yes." It may help reduce your liability. Isn't the report a document stating the condition of the property at the time of the inspection? Yes. Then why use the present tense? At the time you are writing your inspection report, you have already completed your inspection, so you should use past tense in your report to record what you did, what you saw, and what you recommend based upon the inspection performed in the past. When explaining what you did in your inspection, use past tense. Whatever you did, opened, turned on, checked, saw, observed, found, discovered, though, deduced, guessed, recommended - ALL happened at some specific, definite time in the past and is not still being done. Examples: I walked upon the slow-sloped roof and saw a large standing puddle. It was more than 48 since the last rain storm. There were no indications of moisture intrusion as I performed my visual observation of the 2nd floor bedroom ceiling. Your inspection results were relevant only in the past or to a particular time and should not be accepted as a present observation, present condition, or present truth. Example: PRESENT TENSE: The heating system is turning on, is functional and is responding to normal operating controls. PAST TENSE: The heating system turned on, appeared functional, and responded to normal operating controls at the time of the inspection. Are there times when an inspector use the present tense? Yes. You should write your report in the present tense when you want to express something that will continue to be true. Example: PRESENT TENSE: InterNACHI is the world’s largest trade association of residential and commercial building inspectors. Use present tense to express general truths or facts or conclusions supported by your inspection results that are unlikely to change – in other words, something that is believed to be always true. Example: PRESENT TENSE: The garage door is one of the largest moving objects in a home. Improperly installed "safety eyes" of the garage door is a main cause of property damage or bodily injury. Testing and monitoring the garage door operating is an important task related home maintenance. You might use PRESENT TENSE to report your final conclusions. You might use present tense to discuss your observations and their implications. Example: The roof covering material was in poor, deteriorated condition at the time of the inspection. Roof covering in poor condition will likely present a water intrusion problem in the future. Water intrusion and hidden moisture damage is a major concern when the roof system is in poor condition. The roof system requires further evaluation and major repair by a professional. Consider writing your reports observations in the PAST tense. It may help reduce your liability. Last edited by bgromicko; 4/16/10 at 9:02 AM.. |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Good advice. Thanks.
I use past tense.
Same here.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
It's important to use past tense because by the time the client gets the report, the inspection is in the past and the home is not in the same condition it was in during the inspection.
The changes may be so minor that they don't matter, the house may have burned to the ground, or it' condition may be somewhere in between, but inspectors shouldn't use present tense because that report will be inherently inaccurate. An attorney would rip it to shreds in court. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
I write my reports as I am looking at the system, not later on in the office. Therefore, I write my reports as if I am speaking to the client while performing the inspection.
kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Present tense.
I use present tense, since I do reports, and print, on site. Signatures are done that day, and on the reports themselves, for that day.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
I am typing this post as I sit here waiting for my morning appointment. It is 59 degrees outside and the sun is rising from the South/East - shining directly through my windshield. By the time you read my post, it will still be an accurate record of a specific point in time.
I see where this is going ,but doubt it has much bearing.
The report has a date on the cover. Would a Judge read the report and get confused that you are on site as he reads it.? |
I agree with Ben (to use past tense), although I can see where the present-tense users are coming from. As long as the disclaimer is in the Agreement (stating that all observations in the report are true at the date/time of the inspection, and that conditions may change afterward, etc.), I would think that liability would be covered.
I'd add that one should choose a verb tense and stick to it throughout the report, rather than slip from one tense to another.
People and their lawyers look for implied warranties they can squeeze out of present tense wording. Past tense is better protection from liability IMHO.
The AC system is working as intended. The AC system was working as intended at the time of the inspection. Even better No defects where observed in the AC system at the time of the inspection. (isolates a negative, instead of a broad overall endorsement). John McKenna, CMI (TREC #4565)
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 4/16/10 at 1:40 PM.. |
"What does the report say?" Most times, the report says things like, "The roof is in good shape." "The AC unit works." "There are no water leaks." "The sink drains." "There are no foundation cracks." In court, there's a huge advantage of having a plaintiff's attorney stuck in quoting PAST TENSE from your report. He/she can only quote what you wrote, which was written in past tense. Which helps your case. I understand that the disclaimer and agreement can say that the report "documents the condition of the property on the day of the inspection", but I believe it's a stronger position to be in when someone reads your report that is written in the past tense. Last edited by bgromicko; 4/16/10 at 2:03 PM.. |
All that being said ,i often throw in the phrase at time of Inspection, but do not wish to feel I must add that same robotic phrase over , and over and over and over and over after every observation.
The floor was wood and appeared to be oak (at time of the Inspection) Same with (Functional) My reports lean towards narrative,and I try to show respect for my client not being a moron. Guess I left that one open. |
| Report writing may change forever | belliott | General Inspection Discussion | 38 | 9/1/09 12:09 PM |
